maf question
  • Thread starter Thread starter loudexhaust
  • Start date Start date Jun 5, 2008
L
loudexhaust
99
  • Jun 5, 2008
i'm thinking about getting a new maf and would like to get a 24# calibrated one. Thing is I don't want to upgrade my injectors quite yet. So if i get a c&l 76mm maf, can i use my stock maf tube inside the c&l?
vristang
4,933
101
124
Seattle
Jun 6, 2008
  • Jun 6, 2008
What you can do is...
Buy the 76mm MAF with a calibration tube for your current setup (19's)...
and buy a calibration tube for the 24's for later...
You will run the stock sensor in both setups.
There are better aftermarket meters available like ProM and PMAS, and now ABACO
OR
you can buy a stock Ford 70mm MAF for your current setup with 19's.
Use the sensor from the 70mm housing (part number F2VF-****)
You should be able to find them for $25 or so...
My local parts yard gets about $15 for MAF meters.
jason
89streetbeast
365
horton,ks
Jun 6, 2008
  • Jun 6, 2008
why not go carb, i did a few times now since my 89, been hella more responsive and easier to work on , saves more money that buying **** to make **** work imo. but thats just me tho
93gtmustang
524
43
49
Jun 6, 2008
  • Jun 6, 2008
I have the C&L 76mm MAF. It came on my car when I bought it.
I think it works pretty well. When I went from 19# injectors, to 24# injectors, I just ordered up a sample tube for 24's from them. $39.00.
Just make sure you run your stock air box with the C&L. That's what it is designed to be used with.
Anderson Ford motorsports had a self programable MAF sensor which looks pretty cool. I don't know how good they are, but it will save you some money in the long run everytime you change your set-up.
If you plan on running a power adder in the future or making some n/a horsepower, I'd go with a Pro-M or an Anderson Ford MAF set-up with the Anderson Power Pipe
The C&L should be fine otherwise.
You will need to get a sample tube for your 19# injectors
bullitstang1313
713
Indianapolis / Columbus, Indiana
Jun 6, 2008
  • Jun 6, 2008
Why do you want to upgrade your MAF without changing injectors? What is your current setup? Yes the stock 55mm MAF is quite small compared to the SN95's 70mm MAF and all the aftermarket MAFs out there. Have you made any engine modifications that require more air? The benefit of "up-sizing" MAF's without other complimentary modifications will be minimal. And if you have made engine modifications that require the extra air, why aren't you upgrading injectors as well? Just my $.02
L
loudexhaust
99
  • Jun 6, 2008
I'm about to throw on gt40ps, explorer intake, tfs 1, and explorer tb. Figured the maf would be my bottleneck.
93gtmustang
524
43
49
Jun 6, 2008
  • Jun 6, 2008
A larger MAF meter would be a good thing to do.
K
Digital Tuning Going heads/cam/intake. Do I need a tune?
  • karhoot
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 14, 2026
karhoot
K
T
  • Locked
Digital Tuning A9l issue or something else
  • Tufgriz
  • Sep 11, 2025
Fox 5.0 Mustang Tech Sep 11, 2025
T
Fuel Looking for a little guidance
  • Tufgriz
  • Sep 11, 2025
Fox 5.0 Mustang Tech Sep 12, 2025
93 LX 5.0 - 2,000 rpm misfiring, stuttering, and bogging upon acceleration (videos)
  • dan50
  • Saturday at 1:52 PM
Fox 5.0 Mustang Tech Sunday at 7:26 PM
General karthief
Pro-M 75MM Bullet Flow Sheet - Is this calibrated for 36 # injectors?
  • dan50
  • Jan 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Jan 11, 2026
dan50
