MAF question
You'd have to get some tuning done to make the MAF function correctly with yours...I'm pretty sure the maps between them are different. It should probably run, but I think you'll run into some weird issues without correcting the MAF transfer voltages and rates. But, that can all be fixed by a trip to your tuner :D
I am running one on my car right now, and have been for about 2 years. The first year I ran it without a tune, without any issues. The Maf transfers are pretty close between the 55mm and the 70mm.. Just make sure the sensor is clean. I was running a dirty Maf for a while and the tune was all over the place because the Maf wasn't reading correctly. I cleaned the sensor, the car would barely run after that. I had the tune fixed up, now it runs good. So just make sure it is clean.. I used electrical parts cleaner and a q- tip.. Be careful when you do it.
