maf sensor compatability?
  • Thread starter Thread starter itsdamadhatter
  • Start date Start date May 14, 2007
I
itsdamadhatter
10
  • May 14, 2007
will thunderbird with a 4.6 mass air flow sensor work on my 90 lx with a 87 gt swap?
vristang
4,933
101
124
Seattle
May 14, 2007
  • May 14, 2007
That would be a no...
I think JRichker has posted a list of MAF meters before. I think?
A MAF from ANY 94-95 Mustang will work very well, but there is some conversion work you would need to do.
jason
I
itsdamadhatter
10
  • May 15, 2007
im not looking for any conversion just plug and go
93GTosu
183
  • May 15, 2007
well...its not that much work. and it is kinda "plug and go" the only thing you need is an adapter so your intake tubing will attach to the MAF.
try car-parts.com and search for a 90lx "air flow meter"....it will show you junkyards in your area that have them. it searches by part number (i think) so it will also bring up vehicles other than a 90lx.
http://www.swapsupply.biz/ECD/11b-mafapplicationguide.pdf
i found this little list jrichker (very helpful guy ) posted on another thread i was watching. it lists the OEM part numbers and the vehicles they came on.
I
itsdamadhatter
10
  • May 15, 2007
i think i just found one on corral.net for 25 bucks, freakn awesome if its the right one
HISSIN50
34
129
May 16, 2007
  • May 16, 2007
What are you getting? A 55MM stocker or a '94-'95 70 MM version?
If not mentioned, the Sticky link (sticky link doesnt sound too good ) has a thread about the retrofit if needed.
Good luck.
I
itsdamadhatter
10
  • May 16, 2007
its a stock one but im thinking i can customize the housing and either port it or cut out the sensor part and remake it to my intake
HISSIN50
34
129
May 17, 2007
  • May 17, 2007
Bad idea. Don't hose with the MAF and MAS (to use Jason's terminology, which I like).
If you want to remove an inlet restriction, use a correct MAF/MAS assembly that is unaltered. The 94-95 MAF/MAS would have done this well for you.
Good luck.
vristang
4,933
101
124
Seattle
May 17, 2007
  • May 17, 2007
What he said
The MAF and MAS are matched very exactly to each other.
Even removing the screen from a stock 55mm MAF tube can affect its accuracy.
The best (and also very cheap) way to remove restriction due to MAF diameter is the 94-95 Mustang 70mm MAF/MAS.
Here is the thread from the 'Tech Thread Index'
http://forums.stangnet.com/showthread.php?t=616246
If you can use 19lb injectors, this is worth a couple of hp, even on a stock 5.0
jason
Aryan15
236
CA
May 17, 2007
#10
  • May 17, 2007
  • #10
Thanks for posting this. I was thinking about removing that screen. I thought it was just a rock catcher.
vristang
4,933
101
124
Seattle
May 17, 2007
#11
  • May 17, 2007
  • #11
Actually the intent was to help straighten out the aiflow. It is mildly effective.
I would leave it...
If you want to free things up in the MAF, then the 94-95 MAF is the way to go.
jason
I
itsdamadhatter
10
#12
  • May 17, 2007
  • #12
thanks for the info, ill just use this one until i gather up some more cash and ill just upgrade later to a bigger one and bigger injectors, get some ignition work going, but all in all thanks for the help, i just ordered one from another forum for 30 buck from a 90 5.0, so restrictive yes but hey at least it will fix my idle and start up problem
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
W
Engine My engine dies after running 10 to 15 minutes under high heat.
  • Wylieone
  • Jun 21, 2026
Fox 5.0 Mustang Tech Jun 22, 2026
Mustang5L5
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
