MAF sensor question
  • Thread starter Thread starter 885.0conv
  • Start date Start date Nov 2, 2008
885.0conv
238
Phoenix, Az
Nov 2, 2008
  • Nov 2, 2008
I was able to get some 24 # injectors and a 80 MM maf sensor (F5oF-12B579-AA AFH80-01A) from a MARK VIII I believe. I was wondering if the sensor is a direct change or what I need to do to make it work.
M
Mac-man
300
south texas
Nov 2, 2008
  • Nov 2, 2008
if i remember correctly i believe the calibration is in the ecu on fords. an that the aftermarket just reclibrates the meters to use with the factory programming. so i dont know if you will be able to make that work or not without some sort of tuning done to your ecu
HISSIN50
34
129
Nov 2, 2008
  • Nov 2, 2008
Above is correct.
885.0conv
238
Phoenix, Az
Nov 2, 2008
  • Nov 2, 2008
Another question after doing some research on the MAF.
If I were to use the original MAF sensor and go from 55 MM to 80 MM housing and go from 19 to 24 injectors would the bigger size injectors correct for the extra air coming in.
Maryland Stang
1,656
30
39
Greenville, NC
Nov 3, 2008
  • Nov 3, 2008
No. It's would be no different than using the sensor that came with the 80mm unit to begin with. The calibrations will be off no matter what you do.
Maryland Stang
1,656
30
39
Greenville, NC
Nov 3, 2008
  • Nov 3, 2008
Let me add... You can fix this 2 ways.
You can get a "calibrated" housing for your original meter. Granatelli, MAC and others make the housing with the correct sample tube for your 24 pound injectors or...
You can get a chip burned for your ECU that will give the correct calibrations to correct for the 24 pound injectors and 80mm meter.
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Speedometer Calibration
  • Sonny Bibb
  • Sep 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 13, 2026
Sonny Bibb
Engine 95 GT and 95 Cobra sensors and TB gasket
  • Sonic
  • Dec 21, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Dec 23, 2025
WhiteCobra95
