If I were to switch to 42# injectors for a turbo setup for my 91 GT, would a 90MM MAF calibrated for the 42s from a 2001-2004 Lightning be ok to fit on the car?
The Lightning meters aren't calibrated for 42's...
You'll need a custom tune to run the 90mm LMAF, regardless of the injector you select.
Tweecer or Moates if DIY, or get a J3 chip/tune from a dyno shop.
