Maf Suggestions
  • Thread starter Thread starter nickpic
  • Start date Start date Jun 20, 2016
  • 3
First Prev 3 of 3
First5.001
34
Jul 13, 2016
#41
  • Jul 13, 2016
  • #41
Stock injectors. No idea. The guy said the injector size shouldn't matter for the maf. If you're looking at it from the front I put the sensor at 3 o clock.
Sent from my SM-G920V using Tapatalk
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Jul 13, 2016
#42
  • Jul 13, 2016
  • #42
Of course he did, he got you to buy it right? Aftermarket MAF's are calibrated to the injector size. Unless this is a draw through MAF calibrated for 19 lb injectors with a stock airbox put the stock MAF back on.
Admin Dude
Jan 4, 1985
43,535
21,704
234
Box behind Walmart
Jul 13, 2016
#43
  • Jul 13, 2016
  • #43
@First5.001
The injector size doesn't matter if the car is being digitally tuned. The tuner can create a transfer function that will work with any size injector. However...I don't think you want that expense unless you've got enough mods to make it necessary.
mikestang63
Aug 27, 2012
11,606
8,859
214
In the garage
Jul 13, 2016
#44
  • Jul 13, 2016
  • #44
Noobz, did you read the part about STOCK injectors? nuff said
Admin Dude
Jan 4, 1985
43,535
21,704
234
Box behind Walmart
Jul 13, 2016
#45
  • Jul 13, 2016
  • #45
That was directed to @First5.001 .
This was my point. It's not worth doing. The tune alone would run hundreds for no gain regardless of injector size.
I'd sit on that part and wait to see if I ever needed it (assuming he still has it and other mods are planned).
Reactions: First5.001
First5.001
34
Jul 13, 2016
#46
  • Jul 13, 2016
  • #46
Ugh. Ok. Been looking for some 70mm parts at the u pull it. No luck so far. I've got a bunch done to the car, with a 70 mm tb and Holley systemax intake, I figured the stock tb is acting like a restrictor plate.
  • 3
First Prev 3 of 3
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
Engine on3 Conversion to draw through MAF?
  • sav22rem22
  • Oct 11, 2025
Fox 5.0 Mustang Tech Oct 11, 2025
sav22rem22
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Pro-M 75MM Bullet Flow Sheet - Is this calibrated for 36 # injectors?
  • dan50
  • Jan 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Jan 11, 2026
dan50
