MAF upgrade?
Holley aluminum heads bigger valves 1.7 rockers and a camshaft upgrade. Do i need a bigger maf? Current one is part number F1ZF-12B579-AA AFH55-03B with stock injectors.... Car is running really rich is this an issue from the bigger valves and rockers allowing more airflow? or i do i have a bad MAF to begin with?
yes you do NOT swap just sensors. you swap the entire MAF
I don't think I was clear since I feel confused now...lol... So if I have the 55mm factory unit with the "55mm electronics" (calling it that for clarity) on top, I get the 94/95 housing (aluminum only) and do what?
My options are use my existing "55mm electronics" or use the 94/95 electronics.
Mike is laughing at me right now, I know it! :doh:
swap the entire housing with the electronics over. you do not transfer over your sensor to the other housing
