Main Front Crank Seal
Danman765432
471
Nutley, NJ
I think mine might be leaking at little bit since I have a tiny bit of oil coming out from behind my harmonic balancer...My question was how much more would you have to do to install a cam? I figure if I am going to do it I should at least put a cam in since I am taking most of the stuff off anyway and later on when I get money I could always get heads and put those on.
  • Sponsors(?)
BlownFiveLiter
have car, will race....wait, it doesn't run
18
88
Chicagoland
To do the front main seal, you only need to remove the balancer if I recall correctly. It would be quite a bit more work to do a cam though, because you don't even have to remove the water pump or timing cover to replace it.
HISSIN50
SN Certified Technician
27
129
The oil might just be coming out of the key/keyway interface in the HB. If it's just a tiny bit of oil, personally I wouldnt sweat it, but I'm on the lazy side.
The thing about the front seal that kinda scares me is that the metal in the seal feels stronger than the Timing cover. If trying to remove that seal goes bad......... well go get that cam you wanted and install it at the same time :lol:
GT_green_GT
118
I just installed that seal yesterday. All that as to be removed is the harmonic balancer. like hissin50 said, it felt like i woould break the timing cover before i got that seal out. Its in there pretty good.
Danman765432
471
Nutley, NJ
ahh crap I thought this would give me an excuse to do a cam...just wondering what you guys used to take it out and put it back in? Also how long did it take you guys?
mustanggt94
642
Indianapolis, IN
mywebpages.comcast.net
I just did this the other day, though my engine was out of the car! :D
You will want to borrow/rent these two tools:
  • Harmonic Balancer remover (same as steering wheel puller)
  • Harmonic Balancer installer
Using those two tools for the balancer and just using a screwdriver and some elbow grease you can get that old seal out and just tap in a new seal with a rubber mallet or even better use a block of wood or steel try to hammer the seal in evenly. It's a pain sometimes it will go right in and sometimes it takes forever. :bang:
Oh and check real close once you get the balancer off, because I thought my seal was leaking too but it turned out to be the oil pan gasket right there under the timing cover was the culprit. :notnice: (Good thing the motor was out of the car when I figured that out!)
:flag:
Thread starter Similar threads Forum Replies Date
D Front Main Crank Seal...Labor Cost? 1994 - 1995 Specific Tech 11
BlueOvalStangGT How do I install the front crank seal and my rear main seal? Fox 5.0 Mustang Tech 9
revhead347 Front Main Seal Tool 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
93silverlx50 Engine Questions about a front main seal leak and a possible cause Fox 5.0 Mustang Tech 0
D Front Main Seal Removal Question 1994 - 1995 Specific Tech 13
mo_dingo Front Main Seal Problem 1994 - 1995 Specific Tech 2
D Anyone know of a front sump pan (289/302) that clears a main girdle? Classic Mustang Specific Tech 8
B Rear Main Seal, Front Seal, Tranny Pan...All Leaking 1994 - 1995 Specific Tech 4
T Oil pan: front sump for 1 piece rear main seal Classic Mustang Specific Tech 10
D front main seal Fox 5.0 Mustang Tech 3
94GTLaserRC Front Main Seal Replacement 1994 - 1995 Specific Tech 15
9 Front main oil seal.. how hard to replace? Fox 5.0 Mustang Tech 11
E Fox Main electrical feed 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 3
Nightstang00 Main 12v Key on Fox 5.0 Mustang Tech 3
Mustang5L5 Engine Rear Main Seal: Sleeve or no sleeve Fox 5.0 Mustang Tech 11
fredfifty Engine rear main leak Fox 5.0 Mustang Tech 1
twohawks777@cox How to tap a Canton oil pan with main girdle installed on the motor. Digital Self-tuning Forum 2
S 1994 GT / location of main connector for o2 sensor harness 1994 - 1995 Specific Tech 1
S 1994 GT / main harness issue for the o2 harness 1994 - 1995 Specific Tech 2
M New guy from Maine The Welcome Wagon 0
Blown88GT Electrical '87-'93 GT Fog Lamp & Main Light Switch Fix Fox 5.0 Mustang Tech 2
87 black gt Rear main seal sleeve problem 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 3
87 black gt Engine 87 rear main leak Fox 5.0 Mustang Tech 22
T Rear main seal leak?? 1965 - 1973 Classic Mustangs -General/Talk- 2
87 black gt 302 Main Thrust Cap Torque 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
fredfifty Electrical Main Engine Harness (how To Id Year) Fox 5.0 Mustang Tech 4
deathb4dismount Thought I Found The Craigslist Winner Of The Day, Then Maine Said Hold My Beer 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 21
R Rear Noise Mainly On Deceleration 1996 - 2004 SN95 Mustang -General/Talk- 51
3 Rear Main Seal - Leak Check? 1994 - 1995 Specific Tech 1
R Rear Main Fox 5.0 Mustang Tech 2
IH8BOWTIES 4.6 Main Bearings SN95 4.6L Mustang Tech 0
65-Fstbk Fox 1987 5.0 Ho Main Cap Torque 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 3
pissedoff92 Rear Main Nightmare.... Fox 5.0 Mustang Tech 15
RangerJoe Engine Rear Main Fox 5.0 Mustang Tech 4
Rickyll7 SOLD Arp 8740 Main Studs For Iron Block Engine and Power Adder Parts 1
08GTCSTurbo Expired Fuel Pump And Arp Main Studs Engine and Power Adder 6
COramprat Rear Main Seal 1965 - 1973 Classic Mustangs -General/Talk- 4
jmil918 Engine What Size Main/rod Bearings? 1994 - 1995 Specific Tech 6
90lxwhite Fox Rear Main 1 Or 2 Piece 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 14
90lxwhite Ballpark Estimate Labor Rear Main? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 6
Bob Hughes Engine Teksid Main Cap Bolts SN95 4.6L Mustang Tech 3
Bob Hughes Teksid Main Cap Bolts SVT Tech Forum 0
RangerJoe Fox Main Studs 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 15
toxzzic1 Expired 96-99 Vortech Main Mounting Bracket Engine and Power Adder Parts 0
j0rd4n Rear Main Oil Seal? One Or Two Piece? Fox 5.0 Mustang Tech 1
gnx547 New Rear Main Seal Leaking Fox 5.0 Mustang Tech 3
brienjohnson200 Engine 302 Boss Block 2 Piece Rear Main Seal--sealing Problem Fox 5.0 Mustang Tech 9
gnx547 Is My Main Bearings Within Specs? Fox 5.0 Mustang Tech 17
deathsled Leaky rear main seal on the 89 Saleen Fox 5.0 Mustang Tech 8
GoldenEagle91 How to select main bearings? Fox 5.0 Mustang Tech 10
