rd Founding Member Jan 12, 2000 3,316 63 109 Ocean Springs MS Mar 25, 2016 #1 Mar 25, 2016 #1 Getting close to getting the T5 in the 89. Never had a stick shift Fox. What seals the hole in the floor around the shifter?
Shakerhood 20+ Year Stangneter Oct 28, 2004 3,361 211 114 Ohio Mar 25, 2016 #2 Mar 25, 2016 #2 This should be what you are looking for: https://lmr.com/item/LRS-7277E/79-04-Mustang-Lower-Shift-Boot-With-Metal-Ring
rd Founding Member Jan 12, 2000 3,316 63 109 Ocean Springs MS Mar 26, 2016 #3 Mar 26, 2016 #3 Thanks! Could not find that last night. And I have one, it was in my Chevelle pile of stuff.
BMW Rider Mustang Master Oct 9, 2014 140 277 83 Calgary, AB, Canada Mar 26, 2016 #4 Mar 26, 2016 #4 Are you doing a swap from an auto to manual? If so, there is an additional metal piece that is spot welded to the tunnel to fit that shifter boot to. I salvaged one from a wrecked car for mine, but LMR sells them also. https://lmr.com/item/LRS-7277A/1979-93-Mustang-Manual-Transmission-Tunnel-Hump
rd Founding Member Jan 12, 2000 3,316 63 109 Ocean Springs MS Mar 26, 2016 #5 Mar 26, 2016 #5 Yep, doing an auto to manual swap, I saw the tunnel piece last night, did not find the seal. Looks like I will just country boy it for now. I put tarpaper over the tunnel cut in the Chevelle for three years after putting in a tko 600.
