Rio96 said:
Has anyone EVER -->measured<-- the pressure drop across
the stock Maf when the engine is at full power?
Not that I have ever seen, but a MAF is different in that it is measuring (as the name states) mass air flow. This is different than just measuring the amount of air. The MAF takes velocity, volume, and barometric data. Now, I may be a little off-base here, so bare with me, but I think I am making my point.
Modern cars are much more sophisticated and come out of the box already with a much better tune. As a result, modifications do not have the amount of benefits as they did on older cars.
When it comes to mods on 99+ Mustangs:
1 - Leave the MAF alone (as others have stated) unless the MAF voltage is pegged (ie...you need a blower usually)
2 - Leave the fuel system alone unless you are making at least 300 rwhp.
3 - CAI's look nice and really may not do a whole lot for a near stock car. However, as your car "grows" the benefits will become greater.
4 - Increasing the size of your TB is a great, proven mod as long as you go with a new plenum.
5 - Any changes you make to the intake OR exhaust can potentially change your a/f and will generally cause lean and not rich condition.
6 - Stock mustangs generally run a little rich, so a little added lean is not a problem.
7 - You don't need a tune until you have done more that just the normal bolt-ons (unless you are having a problem or have added a MAF). I have never seen a dyno tune do much more than add very few hp on a stock or lightly modded mustang. Not worth the $.
One of these dam days I am gonna make a spreadsheet with all the bolt-ons and associated cost and hp gains.
