Mass Air and Throttle Body??????
  • Thread starter Thread starter FastStang91LX
  • Start date Start date Jan 17, 2010
F
FastStang91LX
31
Minnesota
Jan 17, 2010
  • Jan 17, 2010
I'm sure this had been talked about til people have been blue in the face, but I'm getting tuning done this spring, and want everything in place. What I got is TrickFlow cnc 185 heads, stage 2 cam and their track heat intake. Running a fender cold air kit, 355 gears, 5-speed, A9P computer, fuel pressure regulator, all MSD ingnition components 1 5/8 shorties, 2 1/2 off road X pipe, 2 1/2 Mac after cat, and a 100 horse push button yet to be installed.
My question is: I currently have both 70 and 75mm throttle bodies, 30lb injecors, and am yet to purchase a new mass air meter, but am leaning toward the 80mm cobra one off ebay. The other option of course is the lightning. YOUR THOUGHTS???
The motor probably will get stroked to 331 before spring yet, to build a better bottom end for the trickflow nitrous kit, so I would like that to be considered as well. I know I need at least the 70mm, but would the 75 be better suited even though there is no blower or turbo?
ANY and EVERY bit of help is appreciated.
Tanus
847
A to the Z
Jan 17, 2010
  • Jan 17, 2010
80mm maf with 70mm TB Id say.
F
FastStang91LX
31
Minnesota
Jan 17, 2010
  • Jan 17, 2010
Forgot to mention that my cold air kit (3 1/2 in. before meter, 3 in. to throttle blody) would meet up to 80mm better than the 90mm which is why I am leaning that way, but will not rule the 90 out. Going to supercharge someday, but this motor and associated components will go into wife's car.
If all the votes say 70mm for the throttle body, at what level is the 75 needed? Having 'Stangs for 11 years, I know bigger is not always better.
skunk21
1,203
Taxachusetts
Jan 17, 2010
  • Jan 17, 2010
Grn92LX
Fidanza Man!
6,819
64
129
New York
Jan 17, 2010
  • Jan 17, 2010
75tb. That's what matches the inlet so use it. I'd rethink the cam choice and exhaust selection.
F
FastStang91LX
31
Minnesota
Jan 17, 2010
  • Jan 17, 2010
why is that? You would think TF would make sure all their stuff works together well...
F
FastStang91LX
31
Minnesota
Jan 17, 2010
  • Jan 17, 2010
searching for longtubes on ebay now too, btw. If that's what you meant by exhaust. ANY HELP OR CRITICISM IS GOOD.
F
FastStang91LX
31
Minnesota
Jan 17, 2010
  • Jan 17, 2010
Any other thought?
Any other thought on throttle body and mass air size with my setup?
F
FastStang91LX
31
Minnesota
Jan 18, 2010
  • Jan 18, 2010
bump
P
Pratice
48
NC
Jan 19, 2010
#10
  • Jan 19, 2010
  • #10
75mm tb and 80mm MAF ofcourse
On my 93 gt I'm running a stock bottom end with fox lake ported brodix heads (187 cc).. I'm hoping the car puts down atleast 340hp to the ground on the dyno.
Tanus
847
A to the Z
Jan 19, 2010
#11
  • Jan 19, 2010
  • #11
yeah should be at least 340hp, mines 325 with the stock systemax setup, how much was the extrude hone?
P
Pratice
48
NC
Jan 19, 2010
#12
  • Jan 19, 2010
  • #12
To do the upper intake it was around 400.00 It's not cheap by no means. The hp per dollar ratio doesn't look good either if you just focus on that one part of the combo. But I think with a properly ported lower and a good cam, heads. The Extrude Hone work could be the difference in winning a extremely close race.
To the OP, I think you should atleast run a 410 gear with the stg2 cam. I'm willing to bet with a 355 gear and that cam, your car will be a bucking bronco at anything below 2500 rpm's.
Dont fear the gear...lol
Tanus
847
A to the Z
Jan 20, 2010
#13
  • Jan 20, 2010
  • #13
the extrude hone process always intreged me. I plan to get my holley heads ported and a bigger cam, something like the TFS stage 2 to replace my Z303. right now trap speed is at 110, like to get it to like 115.
tannerc91gt
This last 25% is foreign territory at this point
2,967
234
Indiana
Jan 20, 2010
#14
  • Jan 20, 2010
  • #14
75tb/80maf
it matches the upper. No need to go with a smaller one
Fox Mass Air Flow 42lb injectors
  • 89wreck
  • Aug 18, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 5, 2025
Scrapla347
G
2006 Mustang GT o2 Sensor Wiring Issue Car Bogging/Choking
  • GCantero93
  • Sep 5, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 6, 2025
Requesting Guidance for 306 motor swap - Fuel? - SD? MAF?
  • So_Flo
  • Jul 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
Mcmahst
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
A
SOLD For Sale: 1993 Ford Mustang Cobra Modified
  • anjteal93
  • Sep 5, 2025
2K
Fox Body Mustangs For Sale (1979-93) Oct 26, 2025
Mindseye007
