mass air conversion ???
  • Thread starter Thread starter 2002BLGT
  • Start date Start date Mar 22, 2004
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Mar 22, 2004
  • Mar 22, 2004
Where is the cheapest place to get what I need to do a mass air conversion ??
NYC LSC
626
Staten Island, NYC
Mar 22, 2004
  • Mar 22, 2004
Isn't your car already mass air?
If not, try eBay.
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Mar 22, 2004
  • Mar 22, 2004
friend of mine is getting a 87 coupe , all stock 5spd , 79K miles cowl hood , new paint and welds and new tires for 2300 bucks . trying help him out .
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 22, 2004
  • Mar 22, 2004
MASS air conversion instructions from http://www.stangnet.com/tech/maf/massairconversion.html FREE
A9L computer from junkyard $100-$150
70MM MAF from 94-95 Mustang GT - $40-$70
MASS Air wiring harness kit $30-$85
The whole thing is probably less than $300 using junkyard parts.
Want a 80 MM MAF from the junkyard 'cause 70 MM's too small? See http://www.pro-flow.com/old files/apchart.htm and find an 80 MM MAF that matches you injectors. You might have to swap the MAF's plastic electrical connector, but a safety pin and 10 minutes worth of effort makes that an easy job.
stock50LX
Curmudgeon
1,858
University Place, WA
Mar 22, 2004
  • Mar 22, 2004
Why do you want to convert?
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Mar 22, 2004
  • Mar 22, 2004
probably going to end up doing cam swap soon . just trying to do homework .
Gravel
216
Bellingham WA
Mar 22, 2004
  • Mar 22, 2004
Thanks jrichker!
I had this question but found all the info in a search, well all except the link on the 80mm... U ROCK
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
Engine 91 mustang 302 Low acceleration car backfires pops and acts like it doesn’t want to take fuel
  • 1991Fox5.0
  • Oct 4, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
1991Fox5.0
  • Mindseye007
  • Aug 16, 2026
Mindseye007
K
Digital Tuning Going heads/cam/intake. Do I need a tune?
  • karhoot
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 14, 2026
karhoot
K
Fox Brake lines hitting bump stops
  • keel
  • Sep 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 24, 2026
keel
