I was looking at the 94/95 5.0 mass air meters and they do have a larger 70mm diameter than 55mm fox meters, but there is a large fin down the center of the bore. I would think from a fluild dynamics standpoint that your maximum cfm is compromised since the maximum flow velocity should be a the center of the diameter.
When compared to say a C&L 73 or 76mm bore mass air, the 94/95 mass air would be much more restrictive.
Maybe the 94/95 mass air with the fin doesn't have any limitations to a certain cfm or horsepower rating?
It would be interesting to see a flow diagrahm comparing all these meters to see where they drop off with respect to each other.
I was thinking of doing the 94/95 upgrade cause it was cheap, but I do know that I will be going to 24# pound injectors sometime in the future so maybe a C&L is the best fit because I could use it now and then change out the calibration tube later. I know the Pro-M meters are probably better, the C&L is pretty handy with its calibration tube adjustement.
Another thing, why does C&L produce a 73mm and 76mm mass air? seems like the 73mm was the old design and the 76mm is the new design....why buy a 73 when you can have a 76?
