mass air meter question
  • Thread starter Thread starter lxwants12's
  • Start date Start date Dec 3, 2004
lxwants12's
506
  • Dec 3, 2004
whats a decent mass air meter to o with my new 24# injectors...i had a granatelli for the stock ones but i didnt like te performance of it sometimes the car would idle badly then when i would put the stock one back on it was fine...i was thinking of c&l....its $139 which seems cheap to me thats why i am skeptical about it....my car has a tricflow h/i and e303 cam with all the little goodies..1.6 rockers...fordracing double roller timing chainetc....291rwp...runs lean from 5 grand and up...changed the pump so i wanna hange the injectors i know they are on that edgy limit
R
ratrapp
510
buena vista,va
Dec 4, 2004
  • Dec 4, 2004
try the pro-m unit.i put a 75mm pro-m calibrated for 24lbs on my car and i love it.it'll run around $200 but i think it's well worth it.
AOD86GT
48
USA
Dec 4, 2004
  • Dec 4, 2004
I am with ratrapp, presently using Pro M Bullet for 24lb. inj. Car idles and runs great. I heard with the C&Ls you have to use the stock airbox to work properly.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Dec 4, 2004
  • Dec 4, 2004
Buy the ProM new, not used. I know it's more money, but the folks at ProM calibrate the meter not just for injector size, but also for the type of air intake system and computer you have --- stock box, CAI (with elbows in front of the meter), open conical in the engine bay (PLEASE don't do that); Cobra computer vs. A9L for example -- all those set ups require a different calibration. The problem with buying used is you don't know what intake set up or computer the meter was calibrated for. Good luck with it.
NCStang86
80
selma,nc
Dec 4, 2004
  • Dec 4, 2004
I have a 73 c & l w/ 30 pound injectors and a F303 cam and my car idles perfect. The pro-m is a good meter too. Kinda high priced though
SYLENTBUTVYLENT
136
Chicago
Dec 4, 2004
  • Dec 4, 2004
Go with the pro-m 80mm. Allows for alot of growth, and is the best meter on the market. Try www.jdsperformance.com, they usually have the best prices.
Funanin
356
Horsham, Pennsylvania
Dec 5, 2004
  • Dec 5, 2004
you could get the computer and MAF out of a 93 cobra. They came stock with 24# injectors so they would work nicely together with ur combo. (same as me) but if not i would definitly recommend Pro-M over C&L. Everyone i know has problems with the C&L. To my knowledge the Pro-M is a much better unit.
Z
Engine New head for ‘88 mass air converted foxbody
  • zahirayunus
  • Dec 13, 2024
Fox 5.0 Mustang Tech Dec 13, 2024
zahirayunus
Z
Fox Mass Air Flow 42lb injectors
  • 89wreck
  • Aug 18, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 5, 2025
Scrapla347
I
Engine What Camshaft?
  • Iceman1998
  • Oct 5, 2024
Fox 5.0 Mustang Tech Oct 6, 2024
H
turbo advice
  • hawkinsdrag
  • May 5, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2025
hoopty5.0
Requesting Guidance for 306 motor swap - Fuel? - SD? MAF?
  • So_Flo
  • Jul 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
Mcmahst
