mass air meter question
Bill88Stang
357
Palm Coast FL
i picked up a mass air meter from a fard van its a 80mm unit out of a 98 e150 van. can i take my stock electorics off my 55mm and put it on the 80mm? i just finished converting my 94 lightning to a 89 a9p mustang computer and a bauman trans controller to control the e40d and its currently running off a stick mustang mass air meter which is way to small for the 351. i shoudl be getting a meter from a mark 8 so i can put my 24lb injectors back in shortly once they blow it up at my job for cash for clunkers. but i figured until then i could atleast have it breathing through the bigger mass air housing. thanks
The MAF body and sensor are designed to match each other. Type A sensor works with Type A bodies. Therefore you can't swap sensors between different part number MAF bodies and maintain proper calibration. However, the bodies and sensors are not necessarily calibrated together to create a precision matched pair.
The output voltage of the MAF is a function of the air flowing through it. The MAF itself does not know about injector sizes, nor does it care. All it sees is that an increase in airflow means a corresponding increase of MAF output voltage. Altering the design of the MAF body can alter the flow past the sensor.
The OEM ford system was designed to use internal computer tables to match the voltage output of the MAF to a calculated injector turn on time. The injector table uses only one size injector in its calculations. This is a much more accurate means of determining the engine’s fuel requirements. Using a different MAF than the one the computer was designed for can upset the computer's calculations and the air/fuel ratio.
What aftermarket MAF’s do is try to fool the computer by either changing the amount of airflow over the stock electronics (C&L method) or by altering the sensor itself (Mass Air Systems method). The goal for both methods is to change the output voltage of the MAF so the computer calculates new data that is used to vary the pulse width sent to the injectors.
Unless I am mistaken, C&L tells you to use the MAF sensor that came with the original car. On a 89-93 5.0 Mustang, that was a E9ZF-12B579-xxx
