mass air swap
bluidvl
63
delaware
had a 75mm mass air meter the resister broke.car was in the shop haveing other things done so the guy put on a stock meter and tube.here's the question if i put back on my 75 and used the new meter would it work the same.
Is this "old tube" a C&L or something? your description is not clear to me at all.
If you're talking about taking the electronics out of an OEM meter and putting it into the housing of another brand and size then it will not work. Not unless the housing that you're putting it into has a sample tube that runs in front of the sensing element (like a C&L meter). OEM meter electronics are calibrated for a specifically sized opening. Changing the size of that opening changes actual mass of air that's able to go through that opening. OEM meters are designed to measure air mass through the opening of the meter housing that they came with.
If your old larger sensor housing has a sample tube then it should be designed to use the stock electronics. I have to assume that you understand the difference between a sampling tube and a sensor element housing.
