Hey guys. Ever since I changed out the stock GT brakes to Cobra Brakes (couple years ago), I have some problems with stoping the car. Basically, I've never been able to engage the ABS on the car. If I slam the pedal, the car WILL stop, eventually. The pedal doesn't quiet travel to the floor, but it comes pretty close if I slam it.
Here's what I've done in the last year to try to fix the problem:
new 2 piston Cobra PBR calipers, SS lines, 99+ 13" Brembo rotors, stock Cobra pads and new rear rotors/pads. I made sure I bled the brakes properly (farthest away from the MC) the last time I did it, using a buddy.
Everything has been replace except for the 130,000 mile old master cylinder. My question to YOU is could the MC be the culprit? Could the seals be bad inside the MC? Should I buy the Autozone Special or a Ford new one?
This whole brake thing has been annoying me over the last year or so because I can't get the car to stop like I want it.
Any advice guys?
Thanks.
Any advice guys?
Thanks.
