mech or electric pump?
93project
549
52
38
El Paso, tx
hey guys, I'm on process of converting my 93 to carb. mainly cuz i had a ton of gremlins in my old efi setup and the fact that its a garage car now. anyway, the cost associated with using electric is pushing me to go mechanical. i already have the timing cover for it as well as the eccentric. i see no way of mounting a holley electric below gas tank without it looking ugly. van i get good performance from a 110 holley mech. for a 308, e-street headed .498 lift, edelbrock performer manifold, holley 600cfm setup? thanks
I think the problem you'll have is that around here, most guys stay EFI. There probably isn't a lot of people around here with the EFI-to-carb swap knowledge to help you out, though I'm sure there is at least one or two. Be patient, someone will chime in.
I'd look a little deeper into your fuel pump options. Electric fuel pumps are popular and I'm thinking you should be able to find a fuel pump that suits your needs. Either an external that doesn't need to be lower than the tank or an internal. Start with summitracing. I'd just give them a call and discuss with a tech (not a sales person).
I know you want to hear about mechanical fuel pumps, and perhaps you should post on a 60-70's mustang site about such topics. Even those coverted over to carb here still like their electronic fuel pumps.
PS, maybe look into something like this. PSI looks right. I'd still talk to a tech about it.
http://www.summitracing.com/parts/HLY-12-289-11/
You posted a TECH question in Talk. This limits your chances of getting some really good advice, since most guys aren't looking for Tech stuff in the Talk forum. PM one of the Mods (85ragtop, Killercanary, Mustang5L5, Celeb, FrankenStang, FastDriver ) and ask them to move it to 5.0 Tech. You’ll get a lot more responses to your question.
Having said that, here’s some help…
A word of warning on EFI to carb swaps: don’t expect to pass emissions in any state that does comprehensive smog inspections, because it won’t happen. Be aware that you are violating several Federal laws concerning the removal of pollution control equipment. If you operate the vehicle on public highways and get caught by state or federal law enforcement (doubtful, but possible) you could be subject to fines and imprisonment. You won't get any more power from a carb than you will from EFI.
The following information is intended for informational purposes only. Operation of a motor vehicle modified in such as manner as described below should be limited to off road use only.
Doing the swap: You must know how to read electrical diagrams and wire circuits properly to do the swap. Don’t take shortcuts or cut corners in the fabrication of the electrical or mechanical assemblies. If you do NASCAR quality work, the car will look good, run good and be as reliable as a carb’d car can be. Take pride in a job done with excellence.
If you are one of those few people who do excellent work, please disregard my negative comments. They are not intended for you.
Quality, quality, quality…
Some of the motivation of my negative comments about carb to EFI has to do with the quality of electrical workmanship. A lot of the wiring “repairs” that I have seen on the road and in the junkyard looks like road kill. The other part of my negative view stems from people who can’t grasp the operation and tuning of EFI. Carbs have their own set of requirements and some learning is required to get the best performance. Every car is different and each installation needs to be tuned to get the best performance. Putting an “out of the box carb” or one from someone else’s car isn’t the way to success. There is no auto compensation for small variations in carbs like there is for EFI. Just throwing a carb on a car because you won’t bother to learn how EFI works is a poor excuse. If you are too lazy to read a book and learn how EFI works, your carb car won’t run worth beans either.
Now that the rant is over, here’s some practical advice…
Do not use an EFI in tank fuel pump with a carb. A carb requires 6-8 PSI and the EFI pump puts out 40+ PSI. You will never get the pressure/flow regulated properly. If the add on regulator fails, the resulting overpressure will flood the carb and wash all the oil off the cylinder walls. Engine seizure and death will quickly follow. Either remain EFI or use a tank/fuel pump/fuel lines out of an 84 or earlier Stang. Fabricating your own setup is possible but there are some snags to overcome.
Do not attempt to leave the EFI in place in an attempt to control either the electric fuel pump or ignition. Doing so qualifies you for the “Road Kill Mechanics Award”.
If you try to use your current tank, you will need to pull the fuel pump out and fabricate a pickup tube & strainer sock to replace the fuel pump. Or you can have a sump fabricated and welded onto you existing tank. Many welding shops will not weld fuel tanks because of the dangers involved if the tank isn't purged properly.
You will need an external electric fuel pump unless you change the timing cover for one with the mechanical fuel pump mount on it. Rip all the EFI wiring out, and the computer controlled fuel pump won't work. You will need to add a relay & switch and wire in the existing inertia switch for an external low pressure electric fuel pump. Do not try to wire the fuel pump without the relay. The 15-20 amps the pump pulls will overload the circuit. This will take power away from other items on the same circuit or cause the fuse or fuse link to blow.
attachment.php
You will need to run some new fuel feed lines or braided hose. The 3/8" aluminum tubing works well, but you will need a flaring tool and bending springs to fabricate the lines. Braided hose is easy to run and route, but is much more expensive. It is about $3.50-$4.00 a foot plus the end fittings, which are $3-$4 each. Fabricating hose assembles can be difficult, but anyplace that makes hydraulic hoses can do it for you for an extra charge. See Amazon Hose - Rubber, Hydraulic and Industrial Hose - since 1919 for more information.
For stainless steel braided hose and fittings for automotive use:
See Search Results for stainless - SummitRacing.com
stainless steel hose - JEGS High Performance
See Eaton's Aeroquip Products for more information on High performance automotive hose products
The fancy red & blue AN fittings require a 37 degree flaring tool. A standard automotive or household plumbing tool is 45 degrees and cannot be used with AN flare fittings. If you do, the flare is subjected to too much stress when the fitting is tightened, and is likely to fail or leak.
See Industrial Supply Equipment from MSC Industrial Supply , McMaster-Carr or for the flaring tool you will need . Prices start at $81 and go up
Browse the MSC Big Book
McMaster-Carr
While you are at the electrical part, you'll need a Durspark or similar ignition system with a mechanical spark advance. The 85 Mustang GT 5 speed has a suitable Duraspark distributor with a steel gear compatible with the roller camshaft. The EFI ignition depends on the EFI sensors to advance the spark. Rip out the TPS and MAP/Baro sensors and the computer will have no idea of the proper ignition timing for best performance. Running a fixed timing setting is only for test purposes or for a race track only car. Don't try it on the street: the results will not be nearly as good as a properly setup Durspark or equal. Crane makes a really nice distributor for non-EFI applications. . See CraneCams for more information.
Tools needed:
Crimp tool for connector pins $9-$30 AutoZone, NAPA, Advance Auto Parts or other store
100-150 watt soldering gun (recommend WELLER 8200PK soldering gun kit 100/140W) $30 at Lowes or $40 at Home Depot
3/32”-1/8” rosin core electrical solder, 1/4 lb roll $6 at Ace Hardware, Home Depot or Lowes
Assorted sizes of heat shrink tubing. Buy long pieces and cut length to fit. It is cheaper that way. Parts-Express.com - Heat Shrink Index: 2:1 Ratio, 3:1 Ratio, Heat Shrink Kits
Hot air gun to shrink the tubing ($30-$40) Home Depot
Jeweler’s screwdriver kit $5 at Ace Hardware
Assorted automotive wire, 18-16 gauge 10’-20’ foot spools in different colors. $5 a roll at Advance Auto Parts.
Ford connector pins AutoZone, NAPA or other store $5-$10 for a kit of 10-12 assorted pins
You will have $110-$150 in materials and tools if you don't already have them.
The water temp and oil pressure signals feed from the sender to the main harness through the 10 pin EFI engine harness. To utilize these senders, you need to identify the wires and find a way to reconnect them to the main harness after the EFI engine harness is removed. You need a weatherproof quick connector to join the sender wiring to the main harness.
You will need to construct a wiring harness from the ‘85 carb distributor to the Duraspark box if you go Duraspark, or other distributor to coil wiring.
The voltmeter picks up its signal from the switched voltage present on the instrument panel, so you don’t need to worry about that.
The fuel tank gauge is also independent of the computer wiring.
AutoZone ( | Repair Guides | AutoZone.com ) has wiring diagrams, but you will have to spend some time navigating through the repair data section of their website to find them.
How to solder like a pro - Ford Fuel Injection How To Solder Like a Pro a must read for any automotive wiring job.
Soldering pigtails onto existing pins is road kill quality work as far as I am concerned. Take some time to study the way the Ford connectors are assembled and you will find that a small jeweler’s screwdriver will release the pins from the connector shell. New pins and a crimping tool are available from the Standard Motor Parts or Bendix Electrical parts line that the NAPA & Bumper to Bumper Auto Parts stores carry. Ask any auto parts store about Standard Motor Products or Bendix Electrical wiring parts. Those that carry them will be able to get the parts you need. AutoZone has a cheap kit with 10 pins for about $5. Just enough pins to leave you short when assembling a connector.
One of the interesting things about the Ford OEM wiring diagrams is that the connector shape on the drawing matches the connector shape in the car. That makes it easier to identify connectors and circuits. OEM Ford diagrams are available at for an 85 Mustang at Helm Incorporated: Search Results or can be found in the Chilton series of auto repair manuals for Mustangs.
The following is an excellent idea from a fellow Stangnetter who tackled the wiring plan the right way. He obtained the wiring diagrams from an 85 carb'd V8 Mustang and laid them out side by side with the diagrams from his car. He then traced out each circuit and the wire colors and connectors associated with them. After tracing the circuit and connectors for a circuit, he laid out the changes he needed to make. One circuit at a time made a difficult big job into many smaller easy to manage jobs.
I'm speechless...... Thanks for the amazing amount of info! I do appreciate it. Here's the background on the project.....
Started off as typical 93 efi setup, Ported GT40 Irons, with stud mount conversion, Trickflow stage 1 cam, GT 40 intake, 1.6 crane stud rockers, 76 mm Mass, 70 mm TB, BBK long tubes, Flowmasters, dumps, 3.55's. T5, MSD ignition, VERY little weight, and a 125 shot NX system.
Now due to the damaged harnesses, I removed most of the emissions stuff, and had to get the Deltachip to fudge the reading on the O2's. That harness got nuked by the headers. When the car was warmed up, it ran like a beast. But getting to start in the morning, maintain idle until about an hour into driving, and having an occasional backfire, caused me so many headaches.
I wanted to park the car, rebuild, and restore the car so I could keep it for my daughter(She's 5 :), and my helper). When I pulled the motor and removed the harness, I found even more damage. Torn wires, melted connectors, etc. I took FOUR days to repair the harness myself using the old school chilton(the one with EVERY wiring diagram). I managed to seperate the efi harness from the body harness, which I rewired as well. I got the car's body systems to work perfectly, lights, brake lights, stereo, dash, etc. When I got to building a motor, I was reluctant to use efi again since the car would be a garage queen in her retired life.I already had the car "working", why not just toss a carb setup in there and be done?! Extreme savings for me since I didn't want to reuse any old efi leftovers.
Anyway, I know my way around the car and it's wiring quite well. I already removed the tank and efi pump, BBK 255 BTW, and was not planning on using that for anything. I actually was looking at that Holley 12-289-11 this past week! So the motor is ready to drop in and I guess that Holley is gonna fit the bill for me. 110 GPH sounds good. No reg required either.
As for the car, it has 02 PBR front brakes, new Monroe sensatrac shocks at all corners, new hubs, rotors, Superior 31 spline rear axles, Ranger drums, (yes, I kept Drum) and 18x9 hypercoated FR500's up front and 18x10 hypercoated fr500's in back. The car now sits higher than before. It had 2" drop springs and now has Ford racing b springs.
Sorry for the long post but that way you know where I'm at with this thing. Thanks again for your post!!
