meth on a n/a cobra?
i am thinking of gettin a meth kit on my 99 cobra. i saw in oct issue of mm&ff that snow perf has a meth kit for na cars and i wanted to see what some of you guys think about meth on a na car. there system is a stand alone kit so i dont need a tuner or tune for it, i just use the supplied items to tune it. my mods are jlt cai, o/h pipe, nx kit. and another question can i spray n2o and meth at the same time? is that wise? thanks for the input guys
I believe a meth kit will allow you to run higher compression and more timing without detonation or having to use pump gas. It lowers the incoming air temp. You probably won't see any significant gains unless you tune the car and add some timing to it. In that case, you'll be able to run a lot more timing than you can without the meth...
