  • 2005 - 2009 Specific Tech
MGW shifter question
  • Thread starter Thread starter SpartaPerformance
  • Start date Start date Sep 9, 2007
SpartaPerformance
2,517
61
89
Long Island NY
Sep 9, 2007
  • Sep 9, 2007
Ok I installed it following the instructions to the letter however, when I hit the gas it moves forward, the brakes it moves backwards (don't know how the brakes move a shifter) over bumps it hops up and down and finally it's very notchy feels like the Hurst shifter off the old T-5.....what's up?
mustangmike6996
5 Year Member
Nov 10, 2005
483
clinton twp, MI
Sep 10, 2007
  • Sep 10, 2007
maybe check all of your bushings... as far as shifter mounting and trans and engine as well???? look for cracks of slop in the mounts and rubber....
K
kkdoughboy
212
Pennsylvania
Sep 10, 2007
  • Sep 10, 2007
Sounds like you set the turns out to far and the shifter is slipping out of gear. I only turned mine out about 6 times out of the 12 max. I noticed a significant decrease in throw over stock. I would loosen that bolt again and only turn it out about half way. Then see if the problem persists. I wouldn't drive the car like that alot until you figure out what is causing that. Call them up, the guy I spoke with was very knowledgeable. Keep us updated.
T
TGJ
1,049
  • Sep 12, 2007
On the upgrade kit I got from MGW, the max is 10 turns now...
C
CliffyDeuce
VA
Sep 12, 2007
  • Sep 12, 2007
Mine is very solid. No movement at all. Maybe double check all the mounting bolts under the car to make sure nothing has come loose?
anthony05gt
1,262
Maryland
Sep 12, 2007
  • Sep 12, 2007
Grab hold of it with the engine off and try to pull it up and down. If you have movement, you left the remote beam clamp bolts loose or the 2 nuts in the tranny tunnel that attach the shifter to the sheet metal of the car. If no up and down movement, try putting it in gear and lightly try pushing and pulling it, but not so much as to take it out of gear. If you have slop, you may not have the bushings in.
Progress Thread The Mach Returns - Update/build thread
  • squeak93
  • Feb 20, 2026
1996 - 2004 SN95 Mustang -General/Talk- Yesterday at 4:56 PM
squeak93
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
Forced Induction Bypass valve backwards?
  • Dontknowchit
  • Jun 25, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
JD1964
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Sep 7, 2026
AeroCoupe
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
