WRXracer said:make sure you wrap them up good..
HoustonGT said:Im going with the plug-in ones, what problems have people been having?
P.S.- They're on Ebay for $45.49 shipped, a good price.
I had ran the car for quite a while w/o them then I got them and installed em' Only thing is: I for got to unplug the battery when I did it. The car runs fine but the damn light is STILL ON! I unplugged the battery for a while and reconnected it and drove around until it went through a complete drive cycle, it stayed off; only to come back on again later. I know it's not a genuine problem because I've got an OBDII scanner at work (it shows the P422 or P402 code or something like that, I can't remeber-- excessive exhaust on banks 1 and 2; or something like that). I've even cleared the code with the scanner but it STILL doesn't work. Should I order a NEW set or what? Thanks for ANY help!SALEENstang96 said:I bought a set of MIL Eliminators for Brother's Performance to the tune of about $60.00! BIGGEST waste of money!I had ran the car for quite a while w/o them then I got them and installed em' Only thing is: I for got to unplug the battery when I did it. The car runs fine but the damn light is STILL ON! I unplugged the battery for a while and reconnected it and drove around until it went through a complete drive cycle, it stayed off; only to come back on again later. I know it's not a genuine problem because I've got an OBDII scanner at work (it shows the P422 or P402 code or something like that, I can't remeber-- excessive exhaust on banks 1 and 2; or something like that). I've even cleared the code with the scanner but it STILL doesn't work. Should I order a NEW set or what? Thanks for ANY help!
-Mike
HoustonGT said:Seems like some of the people that are having problems are the ones that forget to disconnect the battery to reset the computer. I hope mine work.
KaPPaBaLL said:I'm not even going to comment on half the BULLSHIOT that these guys are giving you.
Anyway, if you want the MILs get the plug in kind. Plug and play.. www.ebay.com
Splice in my ass![]()
COBRA90GT said:I'm sorry, but HuskerCobra96 is not one of those guys spewing forth any BS in this thread. If you are a fan of plug and play, that's fine - you are entitled to your opinion.
However, splicing in another brand of MIL Elims doesn't make them any lesser. Hell, if I had a nickel for everytime I came across a thread on here or over on Corral about a user having plug & play MIL problems, I would be rich!
I have yet to see someone complain about HuskerCobra96's MIL Elims not functioning properly...
98BLKHRSE said:i have the same problem as these guys..i did reset the computer first...i did install them in the correct spot...the engine code is for those oxygen sensors...ive even used the scanner tool to erase the code and reset the battery...no matter what, the engine light is back on after a few mins of driving...i called a tech at STEEDA and he told me sometimes you need TWO sets of MIL's to fix this type of problem....ive never heard of that and was wondering if any of you have...my feeling is if the first set didnt work, i dont think a second set is gonna fix the problem besides they are $60 a set.
"I've installed PEP's MIL Eliminators on my car and they don't work. What gives?
Before we can give an educated answer, we need to know what DTC's (Diagnostic Trouble Codes) the Car is triggering. Either borrow a code scanner and have the codes pulled, or go to a shop that can scan and pull the DTC's for you. Email the actual code numbers to us, and we'll assist you in troubleshooting the install.
We ask this for a couple of reasons:
There are 100's of variables that could trigger your "check engine" or "service engine soon" light when running an offroad H or X pipe, or gutted stock cats. Let's break down some of the possible installation errors that will cause the MIL Eliminators not to properly keep your "check engine" or "SES" light off after the MIL Eliminators are installed.
Damaged Rear O2 sensor - MIL Eliminators need a healthy O2 sensor signal to work properly.
Incorrect Wiring in of the MIL Eliminator(s).
Rear O2 sensor(s) not properly torqued to spec. in exhaust pipe.
Rear O2 sensor connector not properly plugged in to wiring harness.
Exhaust Leak at the front flange between exhaust manifold or header and offroad pipe.
Front O2 sensor(s) damaged during swap from stock catted exhaust pipe to offroad pipe.
Front O2 sensor(s) not properly torqued to spec. in exhaust pipe.
Front O2 sensor connector not properly plugged into wiring harness.
Was the battery unhooked to reset the PCM (Powertrain Control Module or Computer) before the installation began?
As the installer can see, we have to narrow down the above variables and pinpoint the specific issue before a judgement can be made on whether or not the MIL Eliminators are truly faulty and need to be warrantied. This is precisely why we ask each customer with issues to scan or have scanned the trouble codes before we can make an educated decision on whether or not to warranty the product. 99.99 percent of MIL Eliminator install concerns are due to other variables besides the MIL Eliminators themselves, so pull the codes and write down the actual code numbers before emailing or contacting us for assistance or warranty.
Without the DTC's, we can't be of much help, and won't warranty the product unless we know for sure the MIL Eliminators are at fault. The DTC's will help us make that educated decision. Pull the codes and help us help you."
