i did 27-31 mpg highway from st louis, mo to hilaton head, SC and back this summer. usually do about 25 though
usually 16-20 city. yipee
Pretty impressive, car all stock?
Everyone has their own little way of guessing their milage. And that's what they are...guesses.
how ya figure?
i did 27-31 mpg highway from st louis, mo to hilton head, SC and back this summer. usually do about 25 though
LarsD, i don't want to sound too stupid here, but was your speedo corrected all the way on your 89? 4:10 is a pretty big gear to correct. If it wasn't it would say you had gone farther than you really had, which would be better mileage. 18 is what i just got with my 93 this weekend too, mostly around town mileage. i have gotten 21 with it on the highway before though. My car has 3:55 gears too
Because not everyone calculates their milage the same way and there are too many variables.
Does the car have gears? Is the correct speedo gear installed? The more teeth onthe speedo gear, the more % differential the speedo can be off. Is the odometer accurate to the distance traveled, are the tires factory size? Are the tires factory OEM diameter? Does the tank top off with the exact same number of gallons each time you fill? Is the meter on the gas pump accurate? Has it been calibrated recently?
You start doing +/_ on any of those variables and you can swing your milage up or down slightly.
Plus guys like to add 1 or 2 to everything they measure anyway![]()
