I know there have been a few posts lately about flushing coolant, but none covered this that I found. I've read that it's not a good idea to pull the freeze plugs, so I'll have to pull the thermostat to drain the coolant from the block. Then use a hose to rinse the block out...no big deal I guess. But I've also read that tap water is bad since it corrodes and you're supposed to use Distilled water...cool...cheap stuff, but there's gonna be tap water in the block from the hose. Does that matter? There's not much I can do about it right? So i'll have a mixture of tap water/distilled water/anti-freeze...
