I just got done install them today. Went pretty good. the only problem i ran into was drilling the fourth hole on the driver's side. i didn't scribe it right i guess. it was off buy almost an 1/4" i had to ream the hole out. is this going to matter? there is play there, but not much more than the passenger's side which was dead on when i drilled it out.
I understand that the top/bearing plate adjusts both caster and camber, but the bottom plate that slides front/back what does that adjust? i was using a tool to check the caster/camber and when i was moving that it wasn't changing a thing. i'm assuming toe angle. i'm getting it professionally aligned monday morning. regardless what does that adjustment achieve?
