more power
  • Thread starter Thread starter slow5poh
  • Start date Start date Jul 7, 2005
slow5poh
Senior Citizen
Jul 6, 2005
273
Citrus Heights, CA
Jul 7, 2005
  • Jul 7, 2005
i have a 92 gt. headers,exhaust,gears,alum d/s,shifter,pulleys.
i have never run my car at the track, but it seems slow for what i have done. will a 65mm tbi, bigger maf, and fuel psi reg help?
or should i save up for heads/cam/intake.
i would like to run 13.8-14.0 without having to do much more cause i drive it 70 miles a day. i may have to get a back up to commute in.
marine_2003
427
Lake County, FL
Jul 7, 2005
  • Jul 7, 2005
The throttle body, maf and injectors will make a difference, but you should save for the heads cam and intake. Your cam is your main determining factor for horsepower.
slow5poh
Senior Citizen
Jul 6, 2005
273
Citrus Heights, CA
Jul 8, 2005
  • Jul 8, 2005
yeah i have a set of ported e7te's. layin around. i just didn't want to tear into the motor since it runs good and curently is my only ride. ut i am tired of goin slow too. the other day i barely beat a 90 corvette. that's pretty bad, and a srt-4 beat me the other day, sucks.
dstanggt50
1,316
Woodinville, WA
Jul 8, 2005
  • Jul 8, 2005
The money spent on a maf and t/b, you could get an intake manifold, and that would give you more hp than the others. I would recommend the fpr so you can mess w/fp to see if you can squeeze out any more hp.
slow5poh
Senior Citizen
Jul 6, 2005
273
Citrus Heights, CA
Jul 8, 2005
  • Jul 8, 2005
i was thinking that since i opened up the exhaust, that maybe i need to open up the air intake more too, all i have is a k/n panel filter. Can i hit 14.0's without internals or nitrous?
Modular2v
3,222
23
99
oklahoma
Jul 8, 2005
  • Jul 8, 2005
hey want to sell me those e7s?
ninety15.0
1,336
  • Jul 8, 2005
I would say that u should throw those ported e7's on there with a nice mild cam, an intake....the adjustable fuel pressure reg. at this point would be a waste of your money....if you increase the fp the computer adjusts inj. pulse width and duration accordingly....so there is really no gain on a stock fuel system. even a mild hci will get you to 14.0 with a good driver and the mods you have
1EVIL88VERT
314
Dyess AFB, TX
Jul 8, 2005
  • Jul 8, 2005
save your money and get some nice heads, if your short on money get some y303 heads i've seen them go on ebay for less than 600
slow5poh
Senior Citizen
Jul 6, 2005
273
Citrus Heights, CA
Jul 8, 2005
  • Jul 8, 2005
modular 2v, i might be interested. I got them from a friend of mine who says he had them on his 91 lx. it had a crower cam, the e7's and long tubes, trick flow intake. he said he ran a 12.7 on drag radials. they have stock valves, but have been ported, i wont be on this thread during the weekend cause i don't have internet at home, but will talk to you monday about it, thanks
slow5poh
Senior Citizen
Jul 6, 2005
273
Citrus Heights, CA
Jul 9, 2005
#10
  • Jul 9, 2005
  • #10
forced induction?
i was wondering, how about a 6 psi supercharger? i have 150,000 miles onit. I have heard the stock bottom end won't handle it, but 6 psi isn't much. is it not a good idea or what? cause 1700 bucks would be a easier way to hp without tearing the motor apart. then when it blows up, i can rebuild it with better heads, internals, e cam , etc.
whtpny
338
Spokane WA.
Jul 9, 2005
#11
  • Jul 9, 2005
  • #11
Personally I would have good foundation before the blower. With what you have already, a good MAF a throttle body will definetely help. With those ported E7s and since you have the intake off have the lower ported and you will get a really nice increase. For less than the 1700 and you get fresh heads and can save up for that HCI and shortblock. I wish I had your dilemma!
Scorcher2005
883
South Carolina
Jul 10, 2005
#12
  • Jul 10, 2005
  • #12
the block and internals will easily handle that 6psi and more
whtpny
338
Spokane WA.
Jul 10, 2005
#13
  • Jul 10, 2005
  • #13
Oh I agree that it will handle the 6 psi no problem. Wouldn't that 6 psi be worth alot more if the other stuff was done first?
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Forced Induction Total Timing under boost
  • Dontknowchit
  • Aug 27, 2025
Fox 5.0 Mustang Tech Aug 28, 2025
Dontknowchit
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
