more questions for AODE guys...
what shift kit do you recommend using? i'm mainly considering the Transgo kit or the PA (Performance Automatic) shift improver kit......
i will also be replacing the filter and adding a B&M Supercooler when i get everything together...soooooo....opinions?
I just ended up putting the PA valve body in for our years. It was like $230 from JD's performance. It was a straight forward install, all you had to do was drop the trans pan, unbolt the old valve body and put the new one in, and clip the electronics back on. 3/4 to full throttle and I'm chirping the tires from 1-2. It was so easy to put in, IMO it was worth buying the whole valve body.
