  • 1994 - 1995 Specific Tech
more spark
  • Thread starter Thread starter Mustangless
  • Start date Start date May 24, 2008
Mustangless
903
home
May 24, 2008
  • May 24, 2008
Has anyone ever adjusted their spark tables up 1-6? Currently my spark tables are about the same as the u4p0, except for the higher load/rpms. People adjust their distributors from 10* to anywhere between 11-16*. Since I am using 93 octane isn't it just a waste of higher octane gas not advancing my timing tables?
I looked at the aggressive timing function on tuner exchange, but the tables did not look very aggressive to me.
I am mostly talking about more under 50 load.
or is adjusting timing with the distributer, and messing with the tables two totally different things?
Black95GTS
1,644
Marlborough, MA
May 26, 2008
  • May 26, 2008
Totally different things. When you adjust timing via the distributor, you are adding X amount degrees advance/retard to EVERY value in the spark tables. Its referred to as a "global" adjustment because it affects everything.
When you adjust spark via the tables, you can have different values of advance/retard based on RPM. This is an infinitely more powerful tool. This way you can maintain stock driveability but have all your timing in at a lower RPM. For example, I had all my timing in (32 degrees total on stock E7 heads) by 2500 RPMS at WOT.
Adam
blksn955.o
3,263
st.louis mo 314
May 26, 2008
  • May 26, 2008
If you have a turbo like your sig says then you really probably do not want to get too aggressive at this point.
You will need to look at boosted cars values and details of the tune regarding boost. Most tend to step down in total timing IIRC as RPM goes up.
You also need to pay attention to the load number and RPM as seperate things. Below 50% load your doing more DD/cruise/stop and go type things and that will be a different needed set of values vs. higher loads of .80+ that tend to be your WOT high RPM areas.
Again if your running boost you really need to look at specific boosted tunes/setups as a boosted tune is a whole different ball of wax than N/A and n2o tunes. If you base a boosted cars tune on a non boosted cars tune you will break some stuff.
Mustangless
903
home
May 26, 2008
  • May 26, 2008
I guess I should just leave it how it is.
VE Table Not Dialed? Send Me Your Datalog.
  • X-cam34
  • Feb 8, 2026
  • Digital Self-tuning Forum
  • 2 3
2K
Digital Self-tuning Forum May 1, 2026
X-cam34
Free VE Table Corrections — Drop Your MSQ and a Datalog, I'll Do the Rest
  • X-cam34
  • Apr 12, 2026
  • 2 3
2K
Digital Self-tuning Forum Aug 26, 2026
X-cam34
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
E
Possible dummy questions about Terminator X tuning
  • Ethereal_Zer0
  • Apr 6, 2024
2K
Digital Self-tuning Forum Jul 27, 2024
CAMTWO1070
A
95 Gt intermittent backfire
  • A_A_Ron
  • May 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 26, 2025
A_A_Ron
A
