  • SN95 4.6L Mustang Tech
more suspension work, questions
  • Thread starter Thread starter Torinalth
  • Start date Start date Aug 20, 2006
T
Torinalth
952
Clayton NC
Aug 20, 2006
  • Aug 20, 2006
well, today i removed my front swaybar (steeda) and replaced it with my stock one... this has been suggested by tom for a while since i went with my PHB and was noticing a good bit of understeer.
well, i have the stock front bar on now, and the steeda rear bar still atached. well... i now have a good bit over oversteer. it seems that with the rear swaybar and now the stock front i shot over the neutral area and went from one end to the other... it was only light understeer before and i could control it with countersteering and using inertia to alter my course going into a corner... now however the back end comes out easy, and i can use the steering and power to place the back end where i need it to be... however to go into the corners i now am FORCED to drift through it to keep the speed up... if i keep all corners on the ground i lose a lot of speed.
overall i have definatly lost speed in the corners by going to the stock front bar. however this is where my questions begin. i will be getting the EvM trilink in the next 2-3 months, and they say you need to increase the spring/wheel rate in the rear once you go 3 link (be it tri or TA) as you seemingly increase understeer..... do you think i should leave my spring rate as it once going trilink and see if i neutral out... or think i will be way overboard on understeer without going to a higher spring rate?
another reason i went to the stock front swaybar is that i will be going C/O on all 4 corners a bit after my trilink and was thinking of going to a fairly high wheel rate in the front to eliminate the need for a stronger swaybar... or am i worng here.... closer to the end i will be going to the MM adjustable swaybar so i can dial in the correct front to rear balance.... but until then... what do you guys think?
Torinalth
T
Torinalth
952
Clayton NC
Aug 20, 2006
  • Aug 20, 2006
figured i'd give a bump for the late nighters and keep it on the front page for tomorrow morning
T
T
Torinalth
952
Clayton NC
Aug 21, 2006
  • Aug 21, 2006
wow, have all the guys that know suspension left?
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
N
Fox Street Suspension Build Advice
  • NYFox
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 28, 2026
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
2K
Fox 5.0 Mustang Tech Apr 11, 2026
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
