Moroso Trick Drag Springs - how many coils to cut?
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
I am about to install a set of Moroso Drag front and rear springs. They are about 3" taller than my stockers unsprung. I am thinking 1 and 1/2 coils, does this sound good?
My buddy put some on his camaro, I could almost get my noggin between the tire and wheel well, and that is with drop spindles. He cut 1.5 coils and it put him just where he needed to be.
actully, i would only do a 1/2. i have them, and while its a tad high, i like the agressive looks that it gives off. will attach pics if you want to see. stock springs in the front for now.
I cut 2 coils out of mine. But if I had to do it again,, proabaly would do 1.5 to 1.75. Here is the way it sits with 2 coils out...
stangbear427 said:
Never cut coil springs, especially on a street car.
these springs are acutally meant to be cut depending on the application. Moroso even says to cut them until you get the desired ride height. I cut mine 2 coils but i wish i only cut 1.5, it sits a bit low in the front.
I have those in back. I would not cut them. They made the car all jacked up at first, but after a trip around the block it settled alot. I waited till it was on the ground to tighten the LCA bolts too. I carry about 250lbs in my trunk at all times also. Its been a while since I pulled all that stuff out and went to the track. It had a 3-4" wheel well gap with a stock tire height. With all the stuff in my trunk, it sits level. Almost no wheel gap, so I am happy. Look in my sig for what I have in front, it still wont launch for crap. I am pissed, $1200 for suspension and it went slower, 60' times are higher :bang: Screw this POS! :D
stangman 50 said:
i just bought these trick rear springs will the help do they work or is that a crock of crap? any picks of them un cut?? thanks
check the link in my sig. Moroso springs all around. Front cut 2 coils. DO NOT cut the rear springs at all. They are not meant to be cut. Only the fronts are. The rear sat a little high when i first installed them but then it settled down.
This is going to RULE
Maby I will go 2 coils, I guess I will see how I feel tomorow. I don't daily drive it or anything, but don't want the longtubes to drag either. I have QA1 C/C plates comming my way to take care of any alignment issues. I am so tired of hearing "why does it sit so high up front" and "sitting kinda high".
Thanks again everyone, a lot of help. If mine sits like 50mustang001's car when all is said and done, I will be :) :hail2: :banana: :spot:
sweet car looks awsome, all those pics on the 1st page are with the drag springs, that sits just how i want mine too, thanks for the help..
I cut 1.5 coils and am using a coil spring compressor. I am not putting the isolators or the rubber boot back on the spring, so it may lower it like it had 2 coils cut. I don't have it all in because I am always lacking a tool or something. This front end rebuild is becomming a real PITA for that reason. :notnice:
BTW: How firm/soft are these springs compared to stock once in the car? My buddy put the moroso springs in his Camaro and another buddy did the Eibach drag springs. The moroso's seem firmer but seems to transfer weight better. I wonder if it is the same with a stang.
I didn't really notice a difference during normal drivin. But under hard acceleration the front does lift and it does get a bit scary around corners at a moderate speed.. :( Especially if you aren't runny a sway bar...
This how the expand at the track..This is with stock struts & shocks..
Notice how low the front is when power is applied at them...
Thanks for all your help.
I can't install them. They are so long you have to compress them so much to get them in, and then the tool I am using doesn't work right thanks to ford's great engineering the hole where the rod of the compressor goes through the controll arm is way too small, I can't turn the nut, and if I jack the controll arm to where it is straight through, the whole car lifts up. I've never had this much trouble trying to install a stupid coil spring. Maby I will just try some more but coil-over's will be so much easier.
