Freaking nightmare!!!
jerry beach said:
Sounds like you just need a different spring compressor. You are right, coilovers are easy to put in, as long as you check clearance real well with the wheel in all positions. If you had a good inside coil spring compressor, you would have no problem. Check the part #'s carefully and make sure they sent you the right ones for your car.
I think your right, but I am done messing with it. I think it would be alot easier at work, but at home, PITA. I am so frustrated, this whole project has become a nightmare, and I really don't understand how! I had a gut feeling that I should go with coil overs, when am I going to learn to go with these feelings because everytime I go against them I get in a jam. I just didn't want to have to buy C/C plates yet, but now since I have them, might as well go with my original plan. Here is what I have been through so far:
First I am happy because I ordered the stuff from jegs:
http://forums.stangnet.com/showthread.php?t=487211
Then I have all kinds of shipping issues:
http://forums.stangnet.com/showthread.php?t=489556
http://forums.stangnet.com/showthread.php?t=491719
Finally I get everything and start dissasembling the front end and find all kinds of other crap I need:
http://forums.stangnet.com/showthread.php?t=493353
Then I waste all kinds of time and money on the controll arms:
http://forums.stangnet.com/showthread.php?t=493594
So this project's budget so far has been:
2 x Lakewood 90/10's $180
2 x Lakewood 50/50's $80
2 x Moroso Rear Springs $100
2 x Moroso Front springs $100
QA1 C/C Plates $155
Poly bushings and ball joints for stock controll arms $105.
So I have spent $720 so far, only intended to spend $460, and the time and energy has been equally as draining. Since the Moroso springs are giving me hell I'm going to spend $200 on front coil overs. This justifies my C/C plates but it completly makes my time and effort with the stock controll arms a waste. After time and effort is considered, It would have been much better deal to get aftermarket A-Arms
So in all, I have lost my a$$ in this project, I guess that's what I get for cutting corners. Live and learn. Maby when all is said and done it will be worth it all.
