Motor Build Trouble
  • Thread starter Thread starter TCullen
  • Start date Start date Nov 26, 2006
T
TCullen
28
West Chester, Pa
Nov 26, 2006
  • Nov 26, 2006
My setup is a motor from an 86' with a hydraulic roller cam and adjustable screw in rocker studs, topped off with a demon carb. I just installed a motorsport b303 cam and am having a couple of problems:
1. After 5 minutes of running, the headers glow red hot I thought there was no breakin for the cam?
2. After running for a few minutes, the primary bowl of the carb floods, but not the secondary. I've checked the needle bearing and turned it all the way down, but nothing's worked so far.
3. She backfires like an m-80 when it is shut off, fires through the carb and the exhaust.
Thanks for your help
D
D.Hearne
11,730
south louisiana
Nov 26, 2006
  • Nov 26, 2006
Headers glowing-- timing's retarded. Carb flooding, needle/seat sticking. Readjust the needle/seat to get the fuel back to the sight hole, then give it a sharp rap with a screw driver handle. How did you previously adjust the carb floats? Which 86 5.0 do you have and heads?
T
TCullen
28
West Chester, Pa
Nov 26, 2006
  • Nov 26, 2006
my engine setup is from a scca autocrosser. its got screw in rocker studs, worked over stock heads and forged pistons.
timing was set with the vacume advance still connected. it was set around 25deg BTDC. dumb mistake, so that should clear up the red hot headers.
i've repeatedly adjusted the carb by screwing in the needle assembly, cleaned it out, sang it a song but to no avail. its been removed to check for debris and i found nothing. i'm thinking that perhaps the float might be stuck but then again, i'm new to working with carbs.
D
D.Hearne
11,730
south louisiana
Nov 27, 2006
  • Nov 27, 2006
Change the needle/seat assembly. The sharp rap with a screw driver handle usually dislodges any debris that would make the float stick. It's also possible to have a bad float that's sinking. Too much fuel pressure will sink one, but if the rear float's working, that's not the problem. Remove the bowl, adjust the needle/seat till the float's level with the bowl inverted and put it back on. With this adjustment, only a minor readjust may be neccesary once it's running.
T
TCullen
28
West Chester, Pa
Nov 27, 2006
  • Nov 27, 2006
you were dead on. i switched out the needle assembly and now she runs like a dream. thanks for your help, you probably saved me at lease $300 in shop/towing fees
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
5.0 Rebuild
  • smittys7up
  • Nov 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 16, 2026
keel
Requesting Guidance for 306 motor swap - Fuel? - SD? MAF?
  • So_Flo
  • Jul 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
Mcmahst
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
H
New kid on the block
  • HydraX
  • Mar 22, 2025
  • The Welcome Wagon
The Welcome Wagon Mar 22, 2025
HydraX
H
