Motor Build
  • Thread starter Thread starter 2vjordy
  • Start date Start date Aug 23, 2017
2vjordy
Active User
Jul 19, 2017
  • Aug 23, 2017
What would be better...build a 2v and have brand new forged internals and top end kit with procharger or get a used terminator motor...
I figured build my 2v so I no everything is new and not have to chance getting a messed up used cobra motor I don't no just taking suggestions
squeak93
2,325
405
164
Joplin, Missouri
Aug 24, 2017
  • Aug 24, 2017
Coyote swap. Cheaper in the long run than a full build 2v (ask me how I know). Make that same na power as a stock 2v with a blower.
Neuron
5 Year Member
Nov 6, 2016
859
192
93
Aug 24, 2017
  • Aug 24, 2017
Makes sense somehow, would love to see the numbers.
squeak93
2,325
405
164
Joplin, Missouri
Aug 24, 2017
  • Aug 24, 2017
Stock 2v with blowers put down 375-425 depending on Dyno and bolt ons.
Coyote sees close if not more na all day long especially with bolt ons.
Neuron
5 Year Member
Nov 6, 2016
859
192
93
Aug 25, 2017
  • Aug 25, 2017
The wiring,exhaust, computer and engine mounting( does it bolt up to the original tranny?)at the very least have to be addressed and if you are unlucky enough to be in an emission testing state you might have to deal with them. Would be awesome when done though.
blackgt460
109
21
28
South East Pennsylvania
Aug 26, 2017
  • Aug 26, 2017
Many ways to do a coyote swap with I think relatively minor modifications. A full control unit is sold for the swap. You can go brand new everything which I think costs anywhere from 11-13K with professional installation. Then if you are skilled and can complete the task yourself you can go dirt cheap and find a wrecked mustang or even F150 and go to town. I believe the trans bolts up and there is some custom exhaust needed for the cat back to fit right otherwise just some relocating of a few things under the hood and I think your gauge cluster or some of it will not work anymore with the swap.
robertsa
Well-Known Member
Apr 22, 2017
159
44
58
San Antonio
Aug 26, 2017
  • Aug 26, 2017
Building/buying the 2v will be better than a stock 03 engine and much more economical than a Coyote swap. Do some reading about the Coyote swap; there are many dissatisfied owners. It isn't just a drop in and go deal and many times doesn't run well. Buying a short block is generally cheapest and is backed if purchased from a reputable builder.
Reactions: Neuron
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Buying with a bad motor?
  • djj62478
  • Mar 8, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 11, 2026
TTSaleen
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
Engine Are These rings OK?
  • PonyGTrider
  • Sep 21, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
PonyGTrider
T
2002 V6 3.8L Help Me
  • TheIncompetentMechanic
  • Apr 4, 2026
  • 2 3
1996 - 2004 SN95 Mustang -General/Talk- May 12, 2026
T
