Tx guys for replying (no luck on tweecer, bit slower turn around there).. SO here's the replies to quotes..
(1) yes I should have said lambse, I believe that problem is corrected with #2
(2) uploaded J4J1, set fuel pressure at 35, uploaded MAF transfer, lowered fan temp, car runs much better, idle is solid, power is there till 6000, o2's are working properly, except
(3) Check engine produces 512, Keep Alive Memory test failed or something, and, my KAMRF values during datalog are always at 1.00 (which makes sense, those are the long term correction values held in KAM!).. So what is happening is my car is running rich, LAMBSE tells me that, but KAMRF doesn't adjust it, so its still about 15% rich, no problem, just tune it out, but the CE code bugs me, did I blow my memory, or am I missing that base_checksum = 0 value somewhere? My test today will be to bypass the tweecer (setting 5) and see if this still happens, the I start to get worried ???????
(4) longtubes problem of making the car rich, might be adding to my richness problem, but not really a problem, I'd rather be rich than lean like you've said.
(5) CAR IS LOUD (haha, cats here I come!) stock tailpipes have almost no sound at cruising but when you hit WOT boy do they scream.. (this isn't a problem, yet, haha)
(6) another thing I found when I shift hard 1-2, the car makes a smashing sound in the back, and a crunching sound under the floor.. I'm thinking the rear bushing are shot and the car is too low so the aluminum driveshaft is rubbing..
Other than that, J4J1 fixed a lot of driveability problems, timing is very low, so that'll help boost the power, but that's about it, tx for replying guys, I really appreciate it, and I can't believe how much guessing I'd be doing without stangnet, tweecer, and datalogging !!! (in that order!)
