Mr. Gasket t-stat
  • Thread starter Thread starter jaymac
  • Start date Start date Nov 30, 2005
jaymac
995
Northern Mass
Nov 30, 2005
  • Nov 30, 2005
Not a tech question, but rather a statement.
This has been said before, and I'd like to reiterate the fact.
Mr. Gasket T-stats are the only way to go! Alot of you have chimed in in the past regarding my temp/ heating questions, and might remember a few occasions where my car would overheat big-time, spew coolant, then cool back down. And every morning, the temp would rise to 210* before opening. Well, after the car overheated BIG-TIME on the highway while warming up (car hadn't reached operating temps before I jumped on the highway), I decided it was time for the swap.
Installed it, let it run w/ the drivers side jacked for 15 minutes to burp it and top it off, then took off.
Let me tell you;perfect.
Stat appears to start opening @ 165-170*, and never reaches past 185* to open, (as opposed to the Stant 180* which opened @ 210* on initial warm-up of the day). Cruising it never seemed to rump 182*, and on the highway turning 3000 rpms it saw about 185*, and it used to reach in excess of 195*.
Awesome. I love it. If you don't have one, get one. If you have cooling problems, DEFINITELY get one. Great investment, very happy with it
ss93cobra
1,422
Wilmington NC
Nov 30, 2005
  • Nov 30, 2005
Hmm.. I like my 180 t-stat from Ford. Part # D5PZ-8575-B for those interested.....
M
Mike92GT
583
Florida
Nov 30, 2005
  • Nov 30, 2005
I've been running a Mr Gasket 180 for years. I made the mistake of replacing it with a Stant 180 "Superstat" a few months back. My car instantly started running 15 deg. hotter. Most 180 t-stats are designed to OPEN at 180, so your car will actually run a little hotter then that. The Mr Gasket is designed so your car actually RUNS at at 180, and it is much more accurate
2000xp8
SN Certified Technician
Aug 8, 2003
8,063
1,647
194
NJ
Nov 30, 2005
  • Nov 30, 2005
I've always used the Mr gaskets t stat. Just don't get the 160 if you want heat in the winter.
jaymac
995
Northern Mass
Nov 30, 2005
  • Nov 30, 2005
Ok, I lied. it reached low 190's after initial warm-up and a 4 minute drive, then settled back to 180*... I still dig it
HISSIN50
34
129
Nov 30, 2005
  • Nov 30, 2005
That is the beauty of a balanced stat (if you road raced, etc, you would really love that stat).
Glad it helped!
jaymac
995
Northern Mass
Nov 30, 2005
  • Nov 30, 2005
I think I might have to road race now just to love it some more
8950HO
658
  • Nov 30, 2005
I`ve never had a problem with the parts store "high-flow" thermostats from Moto-Rad.
Much better than running the stock size t-stat.
VE Table Not Dialed? Send Me Your Datalog.
  • X-cam34
  • Feb 8, 2026
  • Digital Self-tuning Forum
  • 2 3
2K
Digital Self-tuning Forum May 1, 2026
X-cam34
Engine Cooling reservoir questions
  • R82148V
  • Oct 3, 2022
2K
Fox 5.0 Mustang Tech Oct 16, 2022
Mustang5L5
F
Cooling System Issue
  • Fri Guy
  • May 15, 2019
2K
Fox 5.0 Mustang Tech May 17, 2019
Blown88GT
Engine Coolant Leak || KOER Test issues - Need Input
  • Killing Hours
  • Mar 27, 2019
4K
Fox 5.0 Mustang Tech Apr 4, 2019
Killing Hours
Engine Lazy T Stat ?
  • TOOLOW91
  • May 12, 2016
Fox 5.0 Mustang Tech May 13, 2016
