MSD ignition mount in fenderwell
zenboy99
2,212
Madison, WI
So I've had my MSD digital 6 ignition box sitting around for a few months waiting for the install of my new 408W. Since thats not happening until this winter, and I have some time on my hands, I figure I'd throw it in this weekend.
I want to put this in the driver side fenderwell for now, I'll probably move it someplace else when I drop the new engine in.
For those of you that have put it in the fenderwell, where did you mount it? Under the washer fluid, or to the right of it? I'm thinking I might remove the washer fluid reservoir and put it there. If anyone has pics of where they mounted it I'd appreciate seeing them.
Put mine by the air filter this time. I have way too much stuff in the fender. The fender wells barely fit as it is. Had it on the firewall when I had the blower.
Yes, much hotter on the firewall compared to where it is now. Couldn't even touch it when it was back there. I've seen the boxes bolted under the air filter before. I wouldn't do under the seat either. It doesn't vent very well under there, I tried it.
Just finished this last weekend. It worked out really well and was very easy. I removed the washer fluid reservoir since I rarely use it. I can access the rpm dials through the hole in the fenderwell so I don't have to remove the wheel to get at it.
I mounted it directly on the other side of the battery. The fenderwell had lots of areas to tie up extra wire.
