Msd Ignition Problem
lordhell
59
Miami Beach
Hey guys, I am using a DIS-4 on my 96 Mustang GT, and since I installed from ***time to time*** i have been experiencing crank up problems, this morning it took me about half an hour to start the car and now I am starting to worry. When trying to start it I also heard explosions from the exhaust.
What can cause this? The installation was done in a professional performance shop and the switches right now are all set up to standard, I mean I havent touched them at all, and all the parts were brand new (tach adapters, ignition), I wonder whats the problem, Is this normal?
Here is a list of my mods just in case you need it.
- Aluminum intake manifold
- BBK OffRoad X Pipe
- MIL eliminator
- MAC Cold Air Intake
- ROUSH Underdrive Pulleys
- MagnaFlow Performance Exhaust
- Ford Racing diffrential Gears 3.73
- Aluminum FMS Driveshaft
- Steeda Speedomter Corrector Gears
- Tires 2 Nitto 555 back 275/40/17
- Tires 2 Yokohama 255/40/17
- Eibach Pro-Kit 1.5" lowered
- Rebulit AODE Transmission (01/01/04)
- Transmission Oil Cooler
- Diablo Delta Chip
- FRPP Jet-Hot Coated Shorty Headers
- AutoMeter Transmission Temp Gauge
- AutoMeter Oil Pressure Gauge
- Brembo Rotors
- Hawk Break Pads
- MSD 8.5mm Super Conductor Wires
- NGK Iridium Spark Plugs
- Battery Hold-Down
- MSD Dis-4 ignition w/ tach adapters and special mounting plate.
the explosions are from fuel getting into the exhaust and igniting in the exhaust, from what you said it doesn't sound like a problem with the MSD, you should check simple problems first, make sure you are getting sparks on all cylinders, it could be a fouled spark plug, wire, or a starter problem
