Ok I am new here and I could really use a little help. I have a 04 V6 convertible that is having an issue with the brake lights, tail lights, instrument cluster, and any form of blinkers. I have read on other forums on here that it's the multifunction switch. I have replaced the multifunction switch and still nothing. I have also checked all fuses, bulbs, and replaced the turn signal relay. I have voltage tested all leads coming into the multi switch and all all reading positive input and I have also changed out the multi function switch connectors but it seems as if Im not getting power out. I don't have a clue of where to go from here or what else I can try. Does anyone have any ideas?
Thank you in advance for any assistance you are able to offer
