Mustang Seat Interchangability....What years are the same?
Will the seat track from a 94-04 donor work with OEM Fox body seat?
92-98 power seat track was the same. So you can use a 98 track with a fox seat.
In 1999, the bottom contour of the drivers seat changed. The mounting holes are on different planes.
I can try and check in the AM if spacers will work. I have a spare 99-04 power track and an 87 seat
So, looks like a 3/4” spacer out back will get the job done with a 99-04 power track. The front two bolts will work, and then you just need an appropriate size spacer between seat and track and a longer bolt in the rear.
you can see the gap here
Unique view
the 99-04 tracks are 6-way adjustable, the 92-98 tracks are 4-way.
