Mustang5l5's Progress Thread - Archived Progress thread '08-'20.
A little progress last night before bed. Working on removing the caked on, factory original timing cover gasket. This took a while. Consisted of applying gasket remover, waiting the necessary 30 mins for it to soften the gasket, and then scraping it off. Clean off and repeat a few times. I might do it one more time tonight.
Replacement core plug is installed.
Getting ready to wash block down with soap, and begin masking for paint.
I still need to chase out all these threaded holes as well. Just need to figure out the sizes I need first. The original bolts were a bit rusty, so they need to be replaced as well.
Nickel and dime
On deck. My Ed Curtis cam and timing chain and then degree it. Timing cover gaskets in the mail, and I’m gonna paint the cover that Eastwood cast aluminum paint I bought for the intake. Should be interesting
Oh...I am waiting for my 5/16 tread chaser to arrive. I also need new hardware.
Nickel and dime has begun
Tossed the camshaft in tonight. Thought it would go easily but hit a snag
Viola
And the damn camshaft dowel pin is too tight. I can get it in the camshaft. I measure the pin at .309, and the receiving hole at .305.
I don’t want to just send it home. I remember these bad Larry’s just sliding on it
Stopped to drink and overpriced IPA and to do some reading on the matter
Reactions: Olivethefet
It’s in.
Got brave. Had a drill but slightly smaller than hole. Pulled cam out, and ran the bit in and out a few times to deburr it. Seemed to do the trick. Dowel fit in now with a few taps of rubber mallet.
Comp supplies two pins a long and short. I know the long one is for the fuel pump on old carb cars, but any technical reason to not run one of it isn’t protruding past the gear?
Reactions: 90sickfox
Found my blue loctite and got the thrust plate installed. Chain on. Got an ARP bolt on the way and I need to degree this before locking it all down.
When I get some time I’ll oil up the new lifters and get those installed.
Time to go rake some leaves for a bit
So while the stop does work on the above manner, I’m still scratching my head over this’s
Taken from “Thunderhead289”s video on degreeing the cam
And yet if I try the same...
I’ll just install like I did before with an oversized washer and call it a day
I only see one part number (4933) for the stop
Edit: realized I bought it off eBay. I suspect it’s a fake now
Finally got a chance to sit down and degree the cam. Set it up dot to dot and everything checked out fine. I was within 1 degree on everything. Broke it down, set it up again and same results.
Ordered wrong ARP cam bolt so new one won’t be here til Monday.
My cam specs
So onto the timing cover install. I need to decide what to do about hardware. So I clean mine up or splurge for new. I took a peek at my water pump and decided time for new one, so I’ll pick one up and grab hardware and do this install next.
I used a bench grinder with a wire wheel to clean up most of the bolts during
my build, unless they are too far gone this can save you some dough.
Could prob clean em up...but most everything external will be new, and I’m doing new hardware most everywhere else
I don’t want to put too much effort into these
