My 05 vert leaks bad
05V6inMD
50
When it rains, water leaks into the area behind the back seat, them makes its way down under the right side rear seat. It pools up inder the seat such that when you sit on the right side in the back seat, the water wicks up through the sponge like seat padding and up through the leather, soaking your pants.
It is a big problems as I am sure it will eventually rot the spongy padding in the seat bottom.
Anyone else have this type of leak in your '05 vert?
You need to get that unit into Ford and raise hell as soon as you can.
Behind the back seat is what is called a "wet well" that drains trough to the bottom of the car. Most convertables have them, it allows the top to fold deeper into the body. You probably have a problem with how it drains. If you don't get it looked after quickly the water can do a lot of damage.
