MY 11.3 @ 122 Car At Track Pics
FSTRDNU
76
i finaly got some shots of the car at the track, too bad the timing was off on the lauch shot, because i hang the left front 1 foot off the ground :)
this is my 1 and only car, it is driven 7 days a week, stock 118k mile 1993 engine, with stock hyper pistons, and stock E7 heads cleaned up, with a novi 1k, at 6lbs, 30 lb injectors, NO FMU, and NO Tune, and alot of boltons
lauch at 5500, would go higher, but it spins like crazy :shrug:
11.3 @ 122, 1.51 60ft
This is quite possibly one of the most impressive posts I have seen on Stangnet in awhile. Daily driven, stock bottom end, 118k mile, hyper pistons, 6psi, no tune, bolt ons, 11.3 @ 122. :hail2:
VERY nice times. :nice:
Man its it amazing you are running that quick with that set up. Its is really one of those " hard to believe stories". Not saying you didn't but its truly hard to believe..
stock 118k mile 1993 engine, with stock hyper pistons, and stock E7 heads cleaned up, with a novi 1k, at 6lbs, 30 lb injectors, NO FMU, and NO Tune, and a lot of boltons
11.30's at 122 with..... on stock rev limiter specially with 6#'s of boost.Even with the benefit of the doubt, lets say you are making more boost(9#'s), and your motor is using more(better breathing) and thats why its only showing 6#'s..... That mph & times are like a stroker motor with good heads and, with a blower , making 10#'s. And more RPM.... Now if this was s deicated track car stripped down, then it would be a little more unsderstandable. But you say it is a daily driver.. And the combo shows it isn't a track car driven on the street.. Not trying to flame you dude,, but those are truly amazing results for such a mild combo. Even with your weight to power ratio, it is really hard to believe.
Like I said man,, not trying to insult you or flame in any form...,, but "D-A-M-N!!" that is fast for a mild combo.. in a daily driver, and not a strip down track car on the street..My hats off to you for it running that quick on that combo:hail2: :hail2: :hail2: :flag:
