My Clutch Pedal is Jiggling...Very Annoying
GTRMan
12
Milwaukie, OR
So about two weeks ago my clutch pedal "became loose" and started wiggling around. It works just fine and there is zero issue with the clutch and im at a loss as to why it did this all of a sudden. Is there a way to tighten the pedal? Oh and its and 04 GT. Thanks in advance.
If the clutch works as it should, I would think that the cable is in the beginning stages of stretching/breaking. So you have a "firewall" adjuster? Or its an after market quadrant/stock cable set up? If still a stock cable and quadrant, take ur toe and lift up on the pedal. This will adjust it using the stock parts.
