  • 1994 - 1995 Specific Tech
My Fox TB converson pics
  • Thread starter Thread starter Eric94GTvert
  • Start date Start date Aug 23, 2004
1 of 2 Next Last
Eric94GTvert
596
PA, Nazareth
Aug 23, 2004
  • Aug 23, 2004
Here are some pics of this weekends Fox throttle body conversion project. I would like to thank GTJAKE for the thread and writeup, without it I wouldn't have even attempted this conversion.
Here are some before/ after comparisions:
look at this old birds nest..
I went from:
94-95 FRPP 65 mm TB
94-95 intake elbow
3" pvc pipe
Pro-m 80mm with stock pro-m filter
To:
Fox Accufab 75mm TB
UPR spacer
4" aluminium intake tubing (polished by me)
same Pro-m 80mm with AFM 8" filter
Kirban vavle cover breather filter
It took me pretty much the whole weekend. Mostly porting the upper intake to 75mm for a nice unrestricted transition and the polishing of the IAC and intake pipe took the most time. The hardest part (for me) was trying to relocate the vacuum hoses under the Edlebrock upper without removing it.
Driving impressions: definately absolutely faster throughout the entire RPM range without a doubt. It really helped my idle and slow cruising.(below 1500 rpms)
This proves to me the elbow IS a huge restriction. I don't have dyno numbers to prove it but I have a huge stack of time slips and will get to the track Friday night to see where I stand.
The only thing I didn't do yet was adjust the TPS. Do I still have to adjust it even though it idles perfectly and runs great. Maybe I just got lucky and it is right on the money.
95Vert
1,785
North Mexico (deep south Texas)
Aug 23, 2004
  • Aug 23, 2004
nice job man, i'm pretty sure that if you don't have any idle issues, it wouldn't hurt just to double check.
you selling the 65mm FMS TB
Eric94GTvert
596
PA, Nazareth
Aug 23, 2004
  • Aug 23, 2004
couple more pics
Eric94GTvert
596
PA, Nazareth
Aug 23, 2004
  • Aug 23, 2004
thanks, Thats what I thought but I'll get a voltmeter this week to be sure.
Yes, I will be selling the 65mm FMS throttle body. It has served me well but it's time to move on.
swingline
1,252
TCB - Taking Care of Business
Aug 23, 2004
  • Aug 23, 2004
Looks good. I'm looking forward to doing mine.
donjohn
1,757
Irvine - Southern California
Aug 23, 2004
  • Aug 23, 2004
Although the setup looks very nice, I fail to see how this proves the elbow was the restrictive source. You went from a 65 to 75mm TB. With the ebrok on there i'd think that the TB is what you should attribute the gain to.
Eric94GTvert
596
PA, Nazareth
Aug 23, 2004
  • Aug 23, 2004
It doesn't matter where the restrictive source is or was. Whatever it was, it is now gone. That is all that matters.
The slightly bigger filter, the bigger inlet pipe, the bigger TB and the elbow removal all help a little.
F
fiveohh94gt
277
  • Aug 23, 2004
looks great, just curious what the total cost of that stuff was to convert it?
sdenorscia
29
Sedona, AZ
Aug 23, 2004
  • Aug 23, 2004
Wow, what a spotless engine. Nice job Chopped Liver.
About how much of an hp gain do you think you got out of the switch out?
donjohn
1,757
Aug 23, 2004
#10
  • Aug 23, 2004
  • #10
haha, nm i thought you were talking about the stupid little elbow itself and not the parts as a whole. i was being retarded
95Vert
1,785
Aug 23, 2004
#11
  • Aug 23, 2004
  • #11
how much???
Numbles
998
Chicago, IL
Aug 23, 2004
#12
  • Aug 23, 2004
  • #12
How much do you want for your Edlebrock Elbow. I need one. PM me.
Eric94GTvert
596
PA, Nazareth
Aug 23, 2004
#13
  • Aug 23, 2004
  • #13
I got the 75mm accufab, tps, iac, gaskets and (accufab egr spacer which I didn't use) for $200 shipped on Ebay
Got the bracket and throttle cable used off the Corral. cheap
The intake spacer was from UPR $40 with shipping UPR
The oil breather was $19
The aluminium intake tubing was $7.20 a foot, I got 2 feet
Tubing
45 degree elbow was $10
elbow
The fernco 4 to 3 reducer was ?? from Home depot
I never really added it up because I bought everything over such a long span of time. As you can see it wasn't cheap. But, I think it was worth it.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Aug 23, 2004
#14
  • Aug 23, 2004
  • #14
Awesome job man! Good call on the 75mm tb unlike what most say Do you know if you can get that 4" piping from home depot as well? The shop I work for (union ) is about to start doing the telecom cabling for a home depot being built here. Theres a home depot expo right next door thats all done, if they sell the tubing I could go there after work and look into what i'd need for a home made 4" pipe. The rubber adapter 4" to 3" fits the 75mm tb good? What about for the 4" tubing to a 80mm pro m?
Eric94GTvert
596
PA, Nazareth
Aug 23, 2004
#15
  • Aug 23, 2004
  • #15
I know you can get 4" piping from home depot but all I could find was PVC. I wanted AL tubing. It looks so much better (after polishing), it is lighter weight, and is easier to work with. I had a PVC CAI for over a year and was tired of it.
The straight Home Depot fernco 3" to 4" reducer was for the Pro-M (3") to intake tube (4") connection.
The 4" rubber elbow 45* bend was hard to find. The above company and link were the only place I could find it. The 4" rubber bend opening fit the throttle body well. I just had to tighten the clamp a little more.
Everything fit together without any ledges or places were flow will be impeded. When I used the thicker PVC there was places where flow would be hindered.(if that makes sense)
Black95GTS
1,644
Marlborough, MA
Aug 23, 2004
#16
  • Aug 23, 2004
  • #16
NICE job on the conversion, looks very clean. Tight looking blue wires too!
The bottleneck was not the bend, however. Increasing inlet diameter has an exponential effect on the output. I took fluid dynamics last year at college. This is why, as Green92LX pointed out, putting on a bigger TB will NOT hurt your performance.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Aug 23, 2004
#17
  • Aug 23, 2004
  • #17
Black95gts, a bigger tb will hurt your performance, I read MM&FF
Black95GTS
1,644
Marlborough, MA
Aug 23, 2004
#18
  • Aug 23, 2004
  • #18
Now what he should do to go faster is run a 55mm tb and run 17lb injectors. I read on this board that will increase power.
Oh and I was re-reading my post, I didn't explain it good. Basically flow loss resulting from bends in the pipes or valves in pipes is called "minor loss." It is minor (duh) and in most applications completely disregarded if the bends aren't larger then 90 degrees. Changes in pipe size are called "major loss" and drastically affect the flowrate. So while in essense you were correct in that you removed a bottleneck, you wouldn't have noticed if say you just eliminated the bend.
Eric94GTvert
596
PA, Nazareth
Aug 23, 2004
#19
  • Aug 23, 2004
  • #19
Well said and it makes sense. Now I have to back it up at the track...
I don't think it will be hard to get better times, because my old times were not exactly stellar. As long as my MPH improves a little, I will be satisfied.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Aug 23, 2004
#20
  • Aug 23, 2004
  • #20
chopped liver, whats your race weight with that vert? Whats your timing set to? I found about 18* to be near ideal on my trickflow headed car.
1 of 2 Next Last
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
Engine Sick of stock TB and EGR spacer...
  • 91GTstroked
  • Dec 15, 2024
Fox 5.0 Mustang Tech Dec 19, 2024
General karthief
Resolved Fixing a GT40P Valvetrain nightmare
  • foxbodyclark
  • May 21, 2025
Fox 5.0 Mustang Tech May 24, 2025
limp
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
