  • 1994 - 1995 Specific Tech
My Gears, Tire Size, 60' Time ?????
  • Thread starter Thread starter Venom351R
  • Start date Start date Jan 14, 2010
Venom351R
4,548
41
98
MAINE
Jan 14, 2010
  • Jan 14, 2010
I currently have 3.73 gears but Im trapping at only 5,000-5,300 in the 1/4 mile. I purchased 4.10 gears but they are not installed (wont be until the spring)I run 26" slicks on 15" weld racing wheels. What I want to know is with 4.10 gears and 26" tires will I need to shift before the 60' mark and if so is that going to reek havoc on my 60' times?
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Jan 14, 2010
  • Jan 14, 2010
No, you probably won't.
Kurt
Venom351R
4,548
41
98
MAINE
Jan 14, 2010
  • Jan 14, 2010
hope not lol,
Black95GTS
1,644
Marlborough, MA
Jan 15, 2010
  • Jan 15, 2010
I think trapping at 5300 RPMS is reaking havoc on your 1/4 mile times. There are lots of internet yodas that will tell you your 60' will be miserable unless you run a 2 speed glide. If you're serious about the 1/4 mile, you want to switch to at least 4.10s. I would think, with that combo, you'd want to shift around 6500, and cross around 6800. You might want to look at 4.30s depending on your target. My $0.02.
Venom351R
4,548
41
98
MAINE
Jan 15, 2010
  • Jan 15, 2010
I already have 4.10's now so Im going to stick w/ those plus I still street drive it enough to not want 4.30's
Tanus
847
A to the Z
Jan 15, 2010
  • Jan 15, 2010
4.10s are perfect for what trap speed your running, once your car is faster you'll need to got to a 28" tire or back to 3.73s
Black95GTS
1,644
Marlborough, MA
Jan 18, 2010
  • Jan 18, 2010
Adam
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Jan 18, 2010
  • Jan 18, 2010
It's actually better to use a 26" tire and a shorter gear than to start arbitrarily putting a taller tire in the back.
Kurt
Venom351R
4,548
41
98
MAINE
Jan 18, 2010
  • Jan 18, 2010
so in other words I'll be fine where I am w/ the 26" tires and the 4.10s once they go in? I know I need to trap higher at the other end so a gear change was a must.
Tanus
847
A to the Z
Jan 18, 2010
#10
  • Jan 18, 2010
  • #10
Black95GTS said:
Adam
whats BS
I dont think you understand what I meant. My car (w/ 4.10s and a 26" tire) traps 110 at 6,500rpm in 4th gear. If I sprayed the car Id redline 4th before the 1/4 mile, so the only options are to shift to 5th gear or drop gearing to 3.73/3.55 or add a taller tire.
Black95GTS
1,644
Marlborough, MA
Jan 18, 2010
#11
  • Jan 18, 2010
  • #11
Tanus said:
whats BS
A nitrous motor is different then a naturally aspirated motor.
Horse power = (trq * RPM) / 5252
With nitrous, you increase horsepower by increasing torque (via the bottle). He doesn't have that option. He can't increase torque so he has to increase RPM. He needs the higher ratio screw to get his RPMs as high as his heads will allow to take advantage of the comparatively narrow power band.
Adam
Tanus
847
A to the Z
Jan 18, 2010
#12
  • Jan 18, 2010
  • #12
dude you dont get what Im saying, 4.10s are perfect for what he has now, but once his car is faster (whether its from nos or a stroker or a blower) with the 4.10s he'll hit redline before the 1/4 mile. thats all Im saying.
Venom351R
4,548
41
98
MAINE
Jan 19, 2010
#13
  • Jan 19, 2010
  • #13
I'll never do Nitrous, I dont plan on a blower and a stroker is to expensive. Im going to try and hit 11's as is. Drop weight, better suspension and still have a few options for adding a bit more in the power department.
Black95GTS
1,644
Marlborough, MA
Jan 19, 2010
#14
  • Jan 19, 2010
  • #14
I give up. Keep on telling naturally aspirated people to lower their rear end ratio as they get faster, but put your flame suit on first.
Adam
Tanus
847
A to the Z
Jan 19, 2010
#15
  • Jan 19, 2010
  • #15
whats the alternative? with a t-5, 4.10s and 26" tire 112-114mph is the fastest you can go in 4th.
Venom351R
4,548
41
98
MAINE
Jan 19, 2010
#16
  • Jan 19, 2010
  • #16
I dont have a T5 I have a Tremec 3550
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Jan 19, 2010
#17
  • Jan 19, 2010
  • #17
Adam
I'm not sure what you are arguing, but he is right. If RPM is the limiting factor, eventually you are going to have shorten the gear to keep from having to shift to 5th, regardless of whether or not the engine is N/A or nitrous. It's a stock block 351, so you can't spin it too high.
Kurt
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Jan 19, 2010
#18
  • Jan 19, 2010
  • #18
It's 1 to 1 in 4th gear with either tranny.
Kurt
Tanus
847
A to the Z
Jan 21, 2010
#19
  • Jan 21, 2010
  • #19
Adam
please enlighten me
Tire size question 1986 gt hatchback
  • B0udreaux
  • Jan 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 17, 2026
B0udreaux
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
Timing chain, guides and tensioner installation (Possible orientation in Intake Stroke)
  • StallionMax
  • Sep 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 24, 2025
StallionMax
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
