My new fuel injection ECM bracket (Big photos beware)
I found that I had limited access to the ECM due to the way I installed it the first time around. I am in the process of adding power windows and a keyless entry system and decided to re-make the bracket and provide room on it for the new parts required of the other installs. It is based on the platform of the old bracket and attaches almost the same way, but just provides me with a little more room than before. Here is what the parts are, looking at the top photo, top on the left is the relay block for the EFI system, fuse blocks are next, one for the EFI the other is for the new added accessories. Across the bottom starting on the left, keyless entry receiver, MassFlo signal converter box, and the relay for the keyless entry system. I used nutserts, the pop rivet like things that leave a threaded hole to mount nearly everything. A neat and easy method should I ever have to service any of these parts.
looks good Jeff!!!! i have one of those Riv-Nut tools and a bunch of Riv-Nuts just waiting on something to use them on.
Brian, the ECM is tunable. Mass Flo recommends you send the ECM back to them for any tuning needs but i think anyone that has an understanding of the ford EEC system can do it.
