My next project , a 428 build!
I got it mostly wired ,still need a 12 volt resister for the unilite and the coil ,and straighten out the spaghetti and run it through some plastic wrap . Then I can hook everything into the key switch . All the connections are soldered and shrink tube .
I need a one wire alternator so I can do away with a voltage regulator .
I ordered my radiator hoses from NPD yesterday and to my surprise they came in today ! I have order many parts from them over the years and I can't say it have ever had a problem!
I need a bypass hose from the water pump to the intake and I can fill it up ,I will pick that up at the same time i get a fuel line and vacuum hoses and it will only leave the carburator and a buddy says he has the needles and secondary diaphragm and excelerator pump witch is all I really need I think!
Did the excelerator pump ,went with the alcohol pump . Going to try the needles and see if they hold .
Still need the fly wheel bolts and the water pump hose fitting but should be here today I hope . Need a carburator gasket still.
Spin techs are bolted on and headers tightened down then I figured out the starter will not go in with the headers on . Fly wheel is on with one bolt so I should be able to pull it and the backing plate and slip the starter in . Just those few things and this thing is ready to fire!
Fly wheel bolted in ,so is the starter. Carburator bolted on ,filled it with antifreeze and a few minutes later I noticed a very slight seep at the heater hose fitting in the intake ,nothing to worry about but once broke in I will pull it and reseal it .
Its ready to start but my nephew Nick wants to hear it fire up so I am waiting till tomorrow ,just need some gas and set in a good battery and hit the switch!
Never fails ,got it all hooked up ,hooked up the tack and I think i fried the distributor module ! I have power to the negative side of the coil and power to the positive side of the coil with key on but no spark from the coil . Looks like another $100 and a couple of days and maybe it will run . I am leaving the tack out this time
  • FacePalm
Reactions: 2Blue2
It was the distributor module ,dropped in the new one and it fired ,then the battery was dead ! Charged it and spun it over ,it was binding so I went to retard the distributor and thats when I found out it was firing between the wires at the cap .
Turned out the lights and spun it over and had a very nice light show! You think changing the boots would straighten it out or just go and pick up another set of wires?
  • Wow
Reactions: DadLife0724
I removed the air mixture screws and sprayed chem tool inside now the screws are adjusting . It's running much smoother and quieter .
The paint I used on the headers hasn't even started to change color even though they smoked heavily when I first started it so must be good stuff!
My new set of plug wires came with an extra set of boots so I striped off the old boots off the other set of wires and put the new ones on ,swaped out three wires with my new set and fired it up ,no more spark jump so now I have another set of good wires.
