My next project , a 428 build!
I got it mostly wired ,still need a 12 volt resister for the unilite and the coil ,and straighten out the spaghetti and run it through some plastic wrap . Then I can hook everything into the key switch . All the connections are soldered and shrink tube .
I need a one wire alternator so I can do away with a voltage regulator .
I ordered my radiator hoses from NPD yesterday and to my surprise they came in today ! I have order many parts from them over the years and I can't say it have ever had a problem!
I need a bypass hose from the water pump to the intake and I can fill it up ,I will pick that up at the same time i get a fuel line and vacuum hoses and it will only leave the carburator and a buddy says he has the needles and secondary diaphragm and excelerator pump witch is all I really need I think!
