My Plans for my car
Guero
2,148
Underdrive Pulleys $109.95
Steeda Tri-Ax Shifter:$179.95
Speedo Gear 23 tooth Manual Transmission $15.95
3.73:1 Ring & Pinion Set $189.95
Throttle Body 70mm $254.56 , what else should i do at this point, i just ordered my edelbrook intake. im doing the heads and cam like in april. so im trying to do all the bolts and stuff before that.
i was thinking about, but do i really need one? I'm just tired of all the noise. Ill check tomorrow to see if its stock or not, how many cats does a stock mustang have(my car came with headers and exhaust, but im not sure if its just cat back.)?
stock is 4 cats. 2 smaller pre-cats and 2big ones
Your planning on spending alot of money for bolt ons..O well. I'd get everything you listed but the gears used if it was me.
I got my trix ax used for 75$, 75mm tb for 125$ (had about 200 miles on it didn't even have any residue on it yet from being used), and underdrive pullies can be had for under 80$. For the 750$ you are planning to spend you could get some decent flowing heads(since stock e7's suck!).
O well just saying seems like I see alot of people on here blowing there money on brand new everything only to be slower then the next guy (like me). :D
Timing Chain? On my grand prix if you put a cam in it you cound't put in different rockers cuz they would hit each other or some **** like that.but you can on the mustang.labora chances are ill get used execept for the gears.plus i wouldn,t be that slow since i got timeslips of 14.96 some are doing that with an intake and gears. Adding those up should take me down to mid to high 13's(thats what im hoping)
I don't know if you will see anything in the 13's with the mods you listed above. It will be close, but dropping nearly a second with those mods will be tough to do IMO. Also, please don't spend $250 on a TB, they can be had much cheaper, still brand new! Unless you are set on getting an Accufab, I would imagine you could get one for around $100 used as Labora said.
i left the prices on there cuz i just copied and pasted from the steeda webpage and was adding all the prices up, chances are i might not change that, since i was reading around the site its not necessary, im going to the track again got some cobra r's with new tires and they grip really good, so im gonna see if i can launch a little harder with out spinning
