My rear brakes still lock up before the fronts...
  • Thread starter Thread starter BlackFox5.0
  • Start date Start date Mar 4, 2004
First Prev 2 of 2
Matt90GT
3,055
Oregon
Mar 5, 2004
#21
  • Mar 5, 2004
  • #21
custom89stang said:
STILL.... his rear brakes shouldnt lock up first. the reason the front does 90% of the braking is cuz the suspension on every car leans forward and all the weight is on the front, thus the fronts usually lock up.
First off understand the physics happening. When you apply the braking force, your weight shifts forward on the car. Thus unloads the rear tires, thus making them easier to lock up. That is why the rear is proportional in pressure to the front.
BlackFox5.0 said:
I have a very good pedal, I already got all the air out of the rear calipers, my struts are still good, they kept going back down when I was trying to hold them up while doing my spindles. I also have stiff springs, and almost no nose dive. Even if I am going under 5mph, they still drag.
I have 245/45 17 tires all around
If they drag, you probably do not have the brackets shimmed properly so the calipers are centered on the rotor. You have to check and double check this measurement!
Also if you use to aggressive of a pad compound on the rear with that setup, you will never get enough front bias dialed in with the off the shelf valves. Go buy some organic pads for the rear or super aggressive front pads.
87gtconv
ragtopman
2,595
Southern Calif
Mar 5, 2004
#22
  • Mar 5, 2004
  • #22
Matt90GT, if I go with less aggresive pads in the front can I get my right front to stop locking up before left front does????
Matt90GT
3,055
Oregon
Mar 5, 2004
#23
  • Mar 5, 2004
  • #23
uhh, no.
Common issue with the 3 port MC bastard.
87gtconv
ragtopman
2,595
Southern Calif
Mar 5, 2004
#24
  • Mar 5, 2004
  • #24
I can sure vouch for that!!
bhuff30
6,037
35
129
Olathe KS
Mar 5, 2004
#25
  • Mar 5, 2004
  • #25
sorry to get back on topic here, but if your pads got any brake fluid or oil on them, they get very grippy, and tend to lock up.
Sounds like you need to find a different master cylinder to fit your application though.
87gtconv
ragtopman
2,595
Southern Calif
Mar 5, 2004
#26
  • Mar 5, 2004
  • #26
Agreed but his sig says he is using the SVO MC and I thought that was the correct one for that set up!! Sorry about my digression!
Maryland Stang
1,656
30
39
Greenville, NC
Mar 5, 2004
#27
  • Mar 5, 2004
  • #27
On the front vs. rear lockup issue my 95 F-150 has rear anti-lock brakes and not the front. Ford would rather have the fronts lock than the rears.
BlackFox5.0
3,514
Massachusetts
Mar 5, 2004
#28
  • Mar 5, 2004
  • #28
I have the top prop valve in this link
http://www.wilwood.com/products/valves/valves.asp
I adjusted it all the way out, to FULL line pressure, so it's like i don't even have the adjustable prop valve.
Matt, I have stock brake pads in the back, I used the ones from the junkyard calipers I used for cores. They still have a lot of pad left so I figured I'd use them, and of course I sanded them flat before I used them.....
I appreciate all the discussion, but it's not really helping to solve the problem...What could be wrong with my setup?
It feels like the rear is locking up way before the fronts are even close to locking.
And Matt, my Cailpers are pretty centered over the rotor, How would it affect the braking if they weren't?
91BlckGT
2,386
75
68
in a van, down by the river
Mar 5, 2004
#29
  • Mar 5, 2004
  • #29
I just got done debugging and fixing a brake locking issue with my car. I had a similar problem like you. Although I'm sure my prob was slightly different, it turns out that my particular issue was that i had the adj. piston in the brake booster adjusted OUT too far. So when ever I drove, the brakes would end up groaning and eventully lock up as the rotors heated up. Not fun. I backed in the nut about 1/16" and that solved my problem.
When your brakes heat up, how much pedal travel do you have before they start to catch? If you have worn pads in the front, and fresh pads in the rear, that might explain it.
Another thing about the prop valve. We have the same one. I have mine adjusted out 5 turns from fully open. Stupid question, but did you mount it correctly? It should look like this:
Matt90GT
3,055
Oregon
Mar 5, 2004
#30
  • Mar 5, 2004
  • #30
Are you not listening to what I post? I am giving you solutions. If you dont like them, tough. Get over it and start wrenching on your problems.
If the calipers are not centered, they will drag like you have stated. Go back and reshim the brackets.
Then go buy some CHEAP organic rear pads for the rear brakes. Who would use "used" pads off a junkyard car??? for $9 you can get new ones. Bad idea since you have no clue what pad compound these pads are.
bhuff30
6,037
35
129
Olathe KS
Mar 5, 2004
#31
  • Mar 5, 2004
  • #31
this is because of the varying loads that your truck will be carrying, which greatly affects the amount of braking that can be done by the rear tires.
BlackFox5.0
3,514
Massachusetts
Mar 5, 2004
#32
  • Mar 5, 2004
  • #32
91BlckGT,my prop valve looks exactly like that, I know it works because I have had to adjust it before....
I just checked my calipers, and the rotors are not centered with the hole in the top of the caliper, should this be where it's centered?
Also how, and where do I shim it? Do I shim the bracket or caliper?
Also when I checked the calipers, the slide pins were sticking out from the caliper about 1/2"
91BlckGT
2,386
75
68
Mar 5, 2004
#33
  • Mar 5, 2004
  • #33
I had to reshim mine (granted, it's a different kit, but you can see here where the shim went). I put in on the anchor place that holds the caliper to the mounting bracket. On one side I had to use a 1/8" shim, the other side 1/16" was plenty. It varies by vehicle because ford usually didn't weld up the axles flanges nice and true.
BlackFox5.0
3,514
Massachusetts
Mar 5, 2004
#34
  • Mar 5, 2004
  • #34
I can't shim it like you did, because there is no caliper bracket like yours. The caliper sits on slide pins, and is held in place by being clamped over the rotor.....the only thing I can think about is the bracket on the axle. But if I put it on the opposite side of the flange, then the caliper doesn't come even close to fitting over the rotor....
speed1972
891
Denver, CO - Buckley AFB
Mar 6, 2004
#35
  • Mar 6, 2004
  • #35
You stated that you have it adjusted all the way out for full line pressure... Is that full line pressure to the back or front? If it is to the back, that is your problem... you need more in the front
First Prev 2 of 2
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
3K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
Fox Brake pedal too stiff
  • keel
  • Sep 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Thursday at 12:24 AM
Shakerhood
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
