- Jul 12, 2017
- 2,477
- 1,349
- 173
You could be right...however...Chinese lube, could be toxic crap. Probably a copy of Corrosion Block, also green, but extremely expensive, which I would not hesitate to use for this application & many others. $20 for a 16oz tub. They now make 3oz tubes.
I use the aerosol spray all the time, $20/can. These are versions of aerospace products, ACF-50
https://www.corrosionblock.com/products/cb-grease.html
I would spray Corrosion Block on the drum that spins on the head unit of the cluster. This stuff is so good, it resurrected the driver's power window switches which work just like new now. If I only had the liquid aerosol, I would use it on the cable, too. I'm in a high humidity environment & switches are easily corroded. Once sprayed with Corrosion Block, it seems to last forever, I mean like years.
West Marine is a stocking dealer, as well as Amazon, etc.
So your recommending spraying that stuff on the head that spins on the back of the speedometer?
